Cannot use More than one Power Sensor from same device in Energy panel
Hi, i have 4 clamp connected to a wemos D1 Mini
esphome:
esp8266:
  board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: ""
ota:
  password: ""
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Energy-Meter Fallback Hotspot"
    password: "bDthQh5QfWbh"
captive_portal:
# Example configuration entry for ESP32
i2c:
  sda: GPIO04
  scl: GPIO05
  scan: true
ads1115:
  - address: 0x48
    continuous_mode: on
  - address: 0x49
    continuous_mode: on
  # - address: 0x50
  #   continuous_mode: on
  #   id: ads1115_50
  # - address: 0x51
  #   id: ads1115_51
time:
  - platform: sntp
status_led:
  pin:
    number: D4
    inverted: True
  # - platform: ct_clamp
  #   sensor: adc_ch1
  #   name: "CH1 Measured Power"
  #   id: ch1_power
  #   update_interval: 5s
  #   accuracy_decimals: 0
  #   filters:
  #     - calibrate_linear:
  #       - 0.0008 -> 0.0
  #       - 0.036 -> 10.87
  #     - lambda: return x * 230;
  #   unit_of_measurement: "W"
  # # Example source sensor
  # - platform: adc
  #   pin: A0
  #   id: adc_sensor
# Channel 1
  - platform: ads1115
    ads1115_id: ads1115_48
    multiplexer: 'A0_A1'
    gain: 1.024
    name: "CH1 Measured Voltage"
    sensor: adc_ch1
    name: "CH1 Measured Current"
    update_interval: 30s
    filters:
      - calibrate_linear:
        - 0 -> 0
        - 1  -> 30
    lambda: |
      if( id(ch1_current).state * 230.0 >= 1 ){
        return id(ch1_current).state * 230.0 /1000;
      }else{
        return 0;
    accuracy_decimals: 3
    unit_of_measurement: "kW"
  - platform: total_daily_energy
    name: "CH1 Dayly Power"
    power_id: ch1_power
    unit_of_measurement: "kWh"
# Channel 2
  - platform: ads1115
    multiplexer: 'A2_A3'
    gain: 1.024
    name: "CH2 Measured Voltage"
    sensor: adc_ch2
    name: "CH2 Measured Current"
    filters:
      - calibrate_linear:
        - 0 -> 0
        - 1  -> 30
    name: "CH2 Measured Power"
    lambda: |
      if( id(ch2_current).state * 230.0 >= 1 ){
        return id(ch2_current).state * 230.0 /1000;
      }else{
        return 0;
    name: "CH2 Dayly Power"
    power_id: ch2_power
# Channel 3
  - platform: ads1115
    ads1115_id: ads1115_49
    gain: 1.024
    name: "CH3 Measured Voltage"
    sensor: adc_ch3
    name: "CH3 Measured Current"
    filters:
      - calibrate_linear:
        - 0 -> 0
        - 1  -> 30
    name: "CH3 Measured Power"
    lambda: |
      if( id(ch3_current).state * 230.0 >= 1 ){
        return id(ch3_current).state * 230.0 /1000;
      }else{
        return 0;
    name: "CH3 Dayly Power"
    power_id: ch3_power
# Channel 4
  - platform: ads1115
    gain: 1.024
    name: "CH4 Measured Voltage"
    sensor: adc_ch4
    name: "CH4 Measured Current"
    filters:
      - calibrate_linear:
        - 0 -> 0
        - 1  -> 30
    name: "CH4 Measured Power"
    lambda: |
      if( id(ch4_current).state * 230.0 >= 1 ){
        return id(ch4_current).state * 230.0 /1000;
      }else{
        return 0;
    name: "CH4 Dayly Power"
    power_id: ch4_power
But from HA in energy settings i can set CH1 Dayly Power in mains but i cannot add ch2 , 3 , 4 on individual devices
Any ideas?
Thank You!
