For whatever reason my HA fails to start when I use the restart function through the web interface. Same goes for updates - HA simply will not start correctly. My log shows the first few seconds after a restart, but then simply ‘stops’
2018-09-30 19:13:16 WARNING (MainThread) [homeassistant.components.http] legacy_api_password support has been enabled. If you don't require it, remove the 'api_password' from your http config.
2018-09-30 19:13:20 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=82 from 2018-09-30 16:59:41.976560)
2018-09-30 19:13:26 ERROR (SyncWorker_11) [miio.device] Unable to discover a device at address 192.168.0.65
2018-09-30 19:13:26 ERROR (MainThread) [homeassistant.components.light.xiaomi_miio] Got exception while fetching the state: Unable to discover the device 192.168.0.65
2018-09-30 19:13:27 WARNING (MainThread) [homeassistant.loader] You are using a custom component for variable which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-09-30 19:13:27 WARNING (MainThread) [homeassistant.loader] You are using a custom component for media_player.xboxone which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-09-30 19:13:31 WARNING (MainThread) [homeassistant.components.climate.generic_thermostat] No previously saved temperature, setting to 21.0
Once I actually tried to restart from the UI, there is no way of getting it back up except for rebooting the whole thing. What is really odd though if I SSH into my device and use ‘hassio ha stop’ and ‘hassio ha start’ it wokrs without any problems. But if it try that method after it failed to start when using the restart from the webinterface, ‘hassio ha start’ won’t work. Any ideas?
