Cannot view config files in File Editor
I am using Scheduler successfully in Wysiwyg mode, however I want to copy the heating schedule below a few times. Niels suggests “The configuration of the card can be done via the UI editor or in YAML”
However when I don’t see any YAML option.
edit dashboard → 3 dots (upper right) → raw configuration editor
is that what you’re looking for? if i’m going to be duplicating or moving whole cards and views, that’s what i use?
The schedule details (times etc) must be sitting somewhere else because they don’t appear in the dashboard YAML
oh, sorry you meant to copy the data. I misunderstood that you wanted to replicate and tweak the card. usually when they talk about the configuration, they are not talking about the content itself.
if I were to guess the content is not intended for hand editing and maybe in the hidden .storage folder… beware if you venture there . make a full backup first.
