Hello, as described on subject, I cannot access from browser to any device after updating ESPHOME to version 5.0. Any lead to give? Thanks
Well without any details impossible to help you What is exact problem in a more detailed description ?
Thanks for the interest Vincen, what detail you need? I’m running HA on Raspi 4 with last version, I just updated ESPHOME to version 5.0 (last version) . First issue was that all devices were shown offline but I was getting all data without any trouble in Lovelace (old name, I know) . I solved by turning on the flag on status_use_ping inside the ESPHOME configuration. Now, everything works fine but cannot visit any device, after a while I get “ERR_CONNECTION_TIMED_OUT”.
I already tried to revert the status_use_ping flag to off, but without success. Any idea?
The ESPHome add-on and the ESPHome integration are two separate entities who are not connected to each other. So if your devices are all working well and delivering all the data as expected, I assume there is a problem with the add-on itself because all your devices are shown offline. Did you change anything in your network? The add-on is using MDNS to resolve the IP-address of your devices, maybe a network change broke MDNS.
Did you already restarted HA to get lost of “hanging” processes regarding the ESPHome add-on? If this doesn’t solve the problem you can try to remove the ESPHome add-on from HA. (Don’t worry all the YAML files are saved in /config/esphome and are not deleted when removing the ESPHome add-on). After removing the ESPHome add-on, restart HA and add the ESPHome add-on again.
And of course make always a backup before you are going “mess around” with your HA instance.
Thanks for the lead. I just restarted the router and now everything is working fine
Most of time the culprit, that’s why it’s crucial to get some good network equipments and not rely on ISP routers among others…
