Hello All is in the tittle, just got the “Loading data” screen.
My pi seems fine,I can ssh it, samba share is ok too. With the log command in putty eveything is “green”
If think i will perhaps try to reinstall hassio (i’ve got a copy of my config folder).
Got the Google assistant component and i Can control all my lights. So hassio seems fine except the web interface.
My log file is below:
2018-03-14 20:06:00 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'CREATE INDEX ix_states_event_id ON states (event_id)'] (Background on this error at: http://sqlalche.me/e/4xp6)
2018-03-14 20:06:00 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'CREATE INDEX ix_states_event_id ON states (event_id)'] (Background on this error at: http://sqlalche.me/e/4xp6) (retrying in 3 seconds)
2018-03-14 20:06:05 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'CREATE INDEX ix_states_event_id ON states (event_id)'] (Background on this error at: http://sqlalche.me/e/4xp6)
2018-03-14 20:06:05 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'CREATE INDEX ix_states_event_id ON states (event_id)'] (Background on this error at: http://sqlalche.me/e/4xp6) (retrying in 3 seconds)
2018-03-14 20:06:06 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
2018-03-14 20:06:09 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'CREATE INDEX ix_states_event_id ON states (event_id)'] (Background on this error at: http://sqlalche.me/e/4xp6)
2018-03-14 20:06:12 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'CREATE INDEX ix_states_event_id ON states (event_id)'] (Background on this error at: http://sqlalche.me/e/4xp6) (retrying in 3 seconds)
2018-03-14 20:06:18 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'CREATE INDEX ix_states_event_id ON states (event_id)'] (Background on this error at: http://sqlalche.me/e/4xp6)
2018-03-14 20:06:18 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'CREATE INDEX ix_states_event_id ON states (event_id)'] (Background on this error at: http://sqlalche.me/e/4xp6) (retrying in 3 seconds)
2018-03-14 20:06:22 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'CREATE INDEX ix_states_event_id ON states (event_id)'] (Background on this error at: http://sqlalche.me/e/4xp6)
2018-03-14 20:06:22 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'CREATE INDEX ix_states_event_id ON states (event_id)'] (Background on this error at: http://sqlalche.me/e/4xp6) (retrying in 3 seconds)
2018-03-14 20:06:25 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'CREATE INDEX ix_states_event_id ON states (event_id)'] (Background on this error at: http://sqlalche.me/e/4xp6)
2018-03-14 20:06:26 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'CREATE INDEX ix_states_event_id ON states (event_id)'] (Background on this error at: http://sqlalche.me/e/4xp6) (retrying in 3 seconds)
2018-03-14 20:06:30 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'CREATE INDEX ix_states_event_id ON states (event_id)'] (Background on this error at: http://sqlalche.me/e/4xp6)
2018-03-14 20:06:30 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'CREATE INDEX ix_states_event_id ON states (event_id)'] (Background on this error at: http://sqlalche.me/e/4xp6) (retrying in 3 seconds)
2018-03-14 20:06:33 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'CREATE INDEX ix_states_event_id ON states (event_id)'] (Background on this error at: http://sqlalche.me/e/4xp6)
2018-03-14 20:06:33 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'CREATE INDEX ix_states_event_id ON states (event_id)'] (Background on this error at: http://sqlalche.me/e/4xp6) (retrying in 3 seconds)
2018-03-14 20:06:36 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'CREATE INDEX ix_states_event_id ON states (event_id)'] (Background on this error at: http://sqlalche.me/e/4xp6)
2018-03-14 20:06:36 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'CREATE INDEX ix_states_event_id ON states (event_id)'] (Background on this error at: http://sqlalche.me/e/4xp6) (retrying in 3 seconds)
2018-03-14 20:06:40 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'CREATE INDEX ix_states_event_id ON states (event_id)'] (Background on this error at: http://sqlalche.me/e/4xp6)
2018-03-14 20:06:40 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'CREATE INDEX ix_states_event_id ON states (event_id)'] (Background on this error at: http://sqlalche.me/e/4xp6) (retrying in 3 seconds)
2018-03-14 20:06:40 ERROR (MainThread) [homeassistant.setup] Setup failed for recorder: Component failed to initialize.
2018-03-14 20:06:40 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of history. Setup failed for dependencies: recorder
2018-03-14 20:06:40 ERROR (MainThread) [homeassistant.setup] Setup failed for history: Could not setup all dependencies.
2018-03-14 20:06:41 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of logbook. Setup failed for dependencies: recorder
2018-03-14 20:06:41 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Could not setup all dependencies.
2018-03-14 20:08:26 ERROR (SyncWorker_9) [homeassistant.util.yaml] Unable to read file /usr/lib/python3.6/site-packages/homeassistant/components/media_player/services.yaml: 'utf-8' codec can't decode byte 0xda in position 3: invalid continuation byte
2018-03-14 20:08:26 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/lib/python3.6/site-packages/homeassistant/util/yaml.py", line 70, in load_yaml
return yaml.load(conf_file, Loader=SafeLineLoader) or OrderedDict()
File "/usr/lib/python3.6/site-packages/yaml/__init__.py", line 70, in load
loader = Loader(stream)
File "/usr/lib/python3.6/site-packages/yaml/loader.py", line 24, in __init__
Reader.__init__(self, stream)
File "/usr/lib/python3.6/site-packages/yaml/reader.py", line 85, in __init__
self.determine_encoding()
File "/usr/lib/python3.6/site-packages/yaml/reader.py", line 124, in determine_encoding
self.update_raw()
File "/usr/lib/python3.6/site-packages/yaml/reader.py", line 178, in update_raw
data = self.stream.read(size)
File "/usr/lib/python3.6/codecs.py", line 321, in decode
(result, consumed) = self._buffer_decode(data, self.errors, final)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xda in position 3: invalid continuation byte
File "/usr/lib/python3.6/asyncio/tasks.py", line 182, in _step
result = coro.throw(exc)
File "/usr/lib/python3.6/site-packages/homeassistant/components/websocket_api.py", line 472, in get_services_helper
descriptions = await async_get_all_descriptions(self.hass)
File "/usr/lib/python3.6/site-packages/homeassistant/helpers/service.py", line 156, in async_get_all_descriptions
loaded = await hass.async_add_job(load_services_files, missing)
File "/usr/lib/python3.6/asyncio/futures.py", line 332, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.6/asyncio/tasks.py", line 250, in _wakeup
future.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 245, in result
raise self._exception
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/lib/python3.6/site-packages/homeassistant/helpers/service.py", line 139, in load_services_files
loaded[yaml_file] = load_yaml(yaml_file)
File "/usr/lib/python3.6/site-packages/homeassistant/util/yaml.py", line 76, in load_yaml
raise HomeAssistantError(exc)
homeassistant.exceptions.HomeAssistantError: 'utf-8' codec can't decode byte 0xda in position 3: invalid continuation byte
