Can't acces homeassistant anymore
After running home assistant for a few months now, I encountered a problem.
I can’t access my home assistant anymore using DUCK DNS, when I removed the prev for HTTPS, I could access it on the local IP.
I got the following error:
File “/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py”, line 314, in data_received
messages, upgraded, tail = self._request_parser.feed_data(data)
File “aiohttp/_http_parser.pyx”, line 546, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: 400, message=“Bad status line ‘invalid HTTP method’”
Does this something have to do with it?
I have noticed DUCK DNS had updated his ip4, so after that, it broke. But either way, it’s the right ip4.
Same here, look like DuckDns is down and up , this problem is almost 16 hours for me at all.
The DNS is up and down all time
Thanks, but why the error tho, like even with perms and duck addon disabled?
I don’t have any error in HA, my server is behind nginx.
This is 100% DuckDns problem
Alright thanks!
