Thank you
hello, maybe this is offtopic but I have problems to enter the addon tasmoadmin in hass.io using NabuCasa remote control,someone could helpme about the configuration with panel iframe,if i enter with browser in 192.168.1.3:9541 is working.thanks
Panel iFrames will not work via NabuCasa remote access unless they are already hosted in a way to be externally accessible. Stick to using ingress for addons you want to see remotely through NabuCasa for best results.
That’s an internal IP, so it should not be expected to work.
Also note, the addon maintainer for TasmoAdmin has already stated: “This add-on can’t support Ingress due to technical limitations.”
thanks for answer,thats mind i need ingress only with local ip to the addon?thanks again
