I just switched to Nabu Casa Remote Control of my HASSIO setup but I cannot for the life of me get Configurator to work. I just get the following when accessing https://xxxxremoteurlxxx.ui.nabu.casa:3128:
**xxxxremoteurlxxx.ui.nabu.casa** took too long to respond.
Remote control works like a charm - access to my iFrames (Web-Configurator, TasmotaAdmin, Zigbee2MQTT-Admin, etc.) would be great too - sadly no VPN access out of my office possibleā¦
It seems like this has been resolved with the latest updates, as you can now hit āOpen Web-UIā while using Nabu Casa, and configurator launches. Does anyone know how to specify the URL of the menu link to work as well? I think hassio.local: is the issue, but I donāt want to hardcode it to the remote link for when I am at home. Here is the link in my configuration.yaml:
When you say {identifier} do you mean the unique identify of my configurator addon? Because it doesnāt have a unique identifier any more with ingress.
Update: The configuration I previously shared only works when accessing Home Assistant via Nabu Casa. I get a ā401: Unauthorizedā when accessing Home Assistant locally.
You can wait for 0.92.0 which should be out on Wed for an easy checkbox to add ingress addons to the side bar, or if you can not wait, below is the correct code to add it to the side bar (using iframes wont work, as you saw):
