My hassio suddenly stopped working a couple days ago and I have no idea what happened. The frontend can no longer be accessed but I can still access the configuration files. No automations or scripts are executing. I’m not sure if anything in the logs identifies the issue. Can someone take a look? I have no clue what steps to take to resolve this issue. Thanks!
(I removed any INFO logs and had to split up the rest due to size)
2020-02-12 17:20:42 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for circadian_lighting which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-02-12 17:20:42 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for badnest which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-02-12 17:20:42 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-02-12 17:20:42 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for spotcast which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-02-12 17:20:44 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=110 from 2020-02-12 22:12:23.636097)
2020-02-12 17:20:48 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for attributes which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-02-12 17:20:58 WARNING (MainThread) [homeassistant.setup] Setup of input_select is taking over 10 seconds.
2020-02-12 17:20:58 WARNING (MainThread) [homeassistant.setup] Setup of input_number is taking over 10 seconds.
2020-02-12 17:20:58 WARNING (MainThread) [homeassistant.setup] Setup of updater is taking over 10 seconds.
2020-02-12 17:20:58 WARNING (MainThread) [homeassistant.setup] Setup of google is taking over 10 seconds.
2020-02-12 17:20:58 WARNING (MainThread) [homeassistant.setup] Setup of group is taking over 10 seconds.
2020-02-12 17:20:58 WARNING (MainThread) [homeassistant.setup] Setup of circadian_lighting is taking over 10 seconds.
2020-02-12 17:20:58 WARNING (MainThread) [homeassistant.setup] Setup of homekit is taking over 10 seconds.
2020-02-12 17:20:58 WARNING (MainThread) [homeassistant.setup] Setup of badnest is taking over 10 seconds.
2020-02-12 17:20:58 WARNING (MainThread) [homeassistant.setup] Setup of input_boolean is taking over 10 seconds.
2020-02-12 17:20:59 ERROR (MainThread) [homeassistant.setup] Error during setup of component api
File "/usr/src/homeassistant/homeassistant/setup.py", line 174, in _async_setup_component
component.setup, hass, processed_config # type: ignore
concurrent.futures._base.CancelledError
2020-02-12 17:20:59 ERROR (MainThread) [homeassistant.components.scene] Error while setting up homeassistant platform for scene
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 159, in _async_setup_platform
await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 435, in wait_for
await waiter
await waiter
await waiter
await waiter
await waiter
2020-02-12 17:20:59 ERROR (MainThread) [homeassistant.setup] Error during setup of component pi_hole
File "/usr/src/homeassistant/homeassistant/setup.py", line 170, in _async_setup_component
File "/usr/src/homeassistant/homeassistant/components/pi_hole/__init__.py", line 166, in async_setup
await pi_hole.async_update()
File "/usr/src/homeassistant/homeassistant/components/pi_hole/__init__.py", line 240, in async_update
await self.api.get_data()
File "/usr/local/lib/python3.7/site-packages/hole/__init__.py", line 37, in get_data
response = await self._session.get(self.base_url)
File "/usr/local/lib/python3.7/site-packages/aiohttp/client.py", line 483, in _request
timeout=real_timeout
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 523, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 859, in _create_connection
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 986, in _create_direct_connection
req=req, client_error=client_error)
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 936, in _wrap_create_connection
return await self._loop.create_connection(*args, **kwargs) # type: ignore # noqa
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 945, in create_connection
await self.sock_connect(sock, address)
File "/usr/local/lib/python3.7/asyncio/selector_events.py", line 473, in sock_connect
return await fut
2020-02-12 17:20:59 ERROR (MainThread) [homeassistant.setup] Error during setup of component group
File "/usr/local/lib/python3.7/asyncio/runners.py", line 43, in run
return loop.run_until_complete(main)
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 583, in run_until_complete
return future.result()
File "/usr/src/homeassistant/homeassistant/__main__.py", line 249, in setup_and_run_hass
safe_mode=args.safe_mode,
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 89, in async_setup_hass
await async_from_config_dict(config_dict, hass)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 132, in async_from_config_dict
await _async_set_up_integrations(hass, config)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 377, in _async_set_up_integrations
*(async_setup_component(hass, domain, config) for domain in domains_to_load)
File "/usr/src/homeassistant/homeassistant/setup.py", line 49, in async_setup_component
return await task # type: ignore
File "/usr/src/homeassistant/homeassistant/setup.py", line 128, in _async_setup_component
await async_process_deps_reqs(hass, config, integration)
File "/usr/src/homeassistant/homeassistant/setup.py", line 290, in async_process_deps_reqs
hass, integration.domain
File "/usr/src/homeassistant/homeassistant/requirements.py", line 55, in async_get_integration_with_requirements
hass, integration.domain, integration.requirements
File "/usr/src/homeassistant/homeassistant/requirements.py", line 99, in async_process_requirements
if pkg_util.is_installed(req):
File "/usr/src/homeassistant/homeassistant/util/package.py", line 44, in is_installed
return version(req.project_name) in req
File "/usr/local/lib/python3.7/site-packages/pkg_resources/__init__.py", line 3138, in __contains__
return self.specifier.contains(item, prereleases=True)
File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/specifiers.py", line 703, in contains
item = parse(item)
File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/version.py", line 31, in parse
return Version(version)
File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/version.py", line 200, in __init__
match = self._regex.search(version)
TypeError: expected string or bytes-like object
File "/usr/src/homeassistant/homeassistant/components/group/__init__.py", line 215, in async_setup
await _async_process_config(hass, config, component)
File "/usr/src/homeassistant/homeassistant/components/group/__init__.py", line 400, in _async_process_config
mode=mode,
File "/usr/src/homeassistant/homeassistant/components/group/__init__.py", line 515, in async_create_group
await component.async_add_entities([group], True)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 265, in async_add_entities
await asyncio.wait(tasks)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 389, in wait
return await _wait(fs, timeout, return_when, loop)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 482, in _wait
await waiter
2020-02-12 17:20:59 ERROR (MainThread) [homeassistant.setup] Error during setup of component config
item = parse(item)
File "/usr/src/homeassistant/homeassistant/components/config/__init__.py", line 70, in async_setup
await waiter
2020-02-12 17:20:59 ERROR (MainThread) [homeassistant.setup] Error during setup of component zone
item = parse(item)
File "/usr/src/homeassistant/homeassistant/components/zone/__init__.py", line 206, in async_setup
await storage_collection.async_load()
File "/usr/src/homeassistant/homeassistant/helpers/collection.py", line 170, in async_load
await self.notify_change(CHANGE_ADDED, item[CONF_ID], item)
File "/usr/src/homeassistant/homeassistant/helpers/collection.py", line 113, in notify_change
await listener(change_type, item_id, item)
File "/usr/src/homeassistant/homeassistant/helpers/collection.py", line 249, in _collection_changed
await entity_component.async_add_entities([entity]) # type: ignore
await waiter
2020-02-12 17:20:59 ERROR (MainThread) [homeassistant.setup] Error during setup of component input_select
item = parse(item)
File "/usr/src/homeassistant/homeassistant/components/input_select/__init__.py", line 111, in async_setup
[{CONF_ID: id_, **cfg} for id_, cfg in config.get(DOMAIN, {}).items()]
File "/usr/src/homeassistant/homeassistant/helpers/collection.py", line 136, in async_load
await self.notify_change(event, item_id, item)
await waiter
2020-02-12 17:20:59 ERROR (MainThread) [homeassistant.setup] Error during setup of component weather
item = parse(item)
File "/usr/src/homeassistant/homeassistant/components/weather/__init__.py", line 48, in async_setup
await component.async_setup(config)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 126, in async_setup
await waiter
2020-02-12 17:20:59 ERROR (MainThread) [homeassistant.setup] Error during setup of component binary_sensor
item = parse(item)
