I had version 0.0xx running on a pi4 and it works fine, but today I clicked the update button to the newest version, then I can’t access to it anymore, It looks like it didn’t connect to my router either (it connect to the router through ethernet).
I have made a snapshot before I update, how can I do to recover all my data?
I’m really not familiar with this, before, I just follow the instruction online step by step to set up my Hassio, so please explain in detail if you can.
Just did.
I still can’t access HA from web browser, now the home-assistant.log file says:
2020-02-03 15:03:43 ERROR (MainThread) [homeassistant.config] Invalid config for [google_assistant]: [report_state] is an invalid option for [google_assistant]. Check: google_assistant->google_assistant->report_state. (See /config/configuration.yaml, line 176). Please check the docs at https://home-assistant.io/integrations/google_assistant/
2020-02-03 15:03:43 ERROR (MainThread) [homeassistant.setup] Setup failed for google_assistant: Invalid config.
2020-02-03 15:03:53 WARNING (MainThread) [homeassistant.components.upnp] Wanted UPnP/IGD device with UDN "uuid:3ddcd1d3-2380-45f5-b069-04d4c4c58138" not found, aborting
