I have my HomeAssistant set up on a Dell Optiplex 3050. It’s connected via LAN to my FritzBox 7590. I’ve set it up and it’s running. Initially, I set up VPN using WireGuard on the FritzBox to connect to HomeAssistant via VPN on my smartphone. It worked, but I didn’t want to always use VPN for this. So, I followed the method using DuckDNS.
I created a DuckDNS account, installed and configured the DuckDNS AddOn in HomeAssistant → it’s working. Here’s the configuration:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
http:
base_url: https://xxxxxxx.duckdns.org:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
cors_allowed_origins:
- https://google.com
- https://www.home-assistant.io
ip_ban_enabled: true
login_attempts_threshold: 5
I also set up DuckDNS as a DynDNS provider in the FritzBox, which provides me with the IPv6 address at DuckDNS.
However, when I try to access my HA from outside using https://xxxxx.duckdns.org:8123, the website is not reachable. It doesn’t work from the local network either. It only works using the local address or the local IP (with https and unsave). I have no idea where to look for the error. Is there a way to find out where the issue might be? Router, HA, or perhaps even the internet provider? I’m with NetCologne.
Yes, both (ipv4 and ipv6) are correct. Since I’ve set up DuckDNS as a DynDNS in the FritzBox, I can also access my FritzBox admin page from outside using the DuckDNS URL and the port configured in the FritzBox.
I’ve actually never seen that done. HTTPS using 8123.
I have seen your posts before, and you are beyond my knowledge of networking so I will defer to you-honestly I have never seen https over a different port.
Yeah it’s definitely valid. If you use 443 as the external port you don’t need to specify a port at the end of the URL if you use anything else, including 8123, you do.
I had the same exact issue with my router who offered a generic DNS service, and you choose the provider. Never seemed to work, and once I setup DuckDNS with a custom service it has been rock solid.
I’m no the king of IPV6, but a leading double colon seems wrong…
It means a consecutive blocks of zeroes, and your HA IPV6 address surely do not start with 00:00…
If you are indeed IPV6 enabled, it would explain why your router cannot reach your HA box.
