First i’d like to mention im a newb, just starting with HA. I flashed the OS on a SD card, connected to my PI 4b, but i am unable to connect to the HA url.
I connected the PI to a monitor, and HA is booting fine, however I noticed its not getting any IP address assigned. I don’t have a keyboard to connect to the PI…
Is the ethernet cable plugged in at each end (I jest not, I spent hours debugging a network problem once, only to discover the cable wasn’t plugged in).
i don’t know how this “image” looks like you flashed, if it’s expecting a WiFi connection or Ethernet, and network-settings etc. … But i would try to “reboot” your PI again( if you not already tried that )
Not sure I follow…How I can run the terminal on the PI if it doesn’t get an IP address and I cannot connect to it? I need a keyboard that i can connect to PI.
A laptop may run PC software, but “PC” is as generic a word as is “Car”. A Volkswagen and a Lexus are both cars.
My desktop PC has multiple internal drives including a separate disk for my Documents folder, a mirror backup and a scratch drive. My desktop PC has three 24-inch screens, six USB3 ports, a Firewire expansion board, 5.1 audio and a USB keyboard.
My mistake was assuming that when the OP said “PC”, he meant a desktop PC.
