I was responding to Nick, Stephen.
As long as you understood what he was saying.
What is the outcome solution? I have the same exact issue and have been cussing after days trying to get it to work!!!
I had mine working for a long while on an HP thin client with HAOS the same as the set up here. It was a breeze all connected and working for months. About a week ago i can no longer access to the server via homeassistant.log in or the ipaddress directly. I reintstall fresh again and it will not connect.
Exaclty the same issue as was described here.
Help anyone!!!
Unfortunately, I don’t actually know what the exact issue was. The container wasn’t running correctly on my first attempt so I (1) wiped everything on my Thin Client and USB, (2) put a fresh Ubuntu via Batcher on my USB, (3) and reinstalled everything the exact same way and then it worked.
I just had exactly the same issue and resinstalled it twice on my mini-pc. It failed to log in with Firefox but was able to get the login page just fine with Chrome.
Anybody solve that problem? I had problem with old instance so i bought new rospbery and install new HA. I have change IP to static and also can’t reach HA via webbrowser. Via HDMI connection i see that system is ready.
Hi, welcome to the forum!
What are you entering in your browser as an address?
