I have been running HA with the DuckDNS add-on for about 2 year. I’m currently running…
Core - 2024.4.0
Supervisor - 2024.04.0
Operating System - 12.1
Frontend - 20240403.1
This is running in a VM in Oracle Virtual Box on top of Ubuntu.
A few nights ago, my ISP turned off internet access for routine maintenance and since it has come back, I am unable to access HA externally. I am able to access my instance via https://192.168.0.30:8123 and all seems fine.
The DuckDNS add on has the following in the logs:
[17:38:53] INFO: OK
XXX.XX.XX.34
NOCHANGE
[17:43:54] INFO: OK
XXX.XX.XX.34
To me that suggests all is good and it matched my public IP address. I have also done a DNS look up on my DuckDNS sub domain and that seems to resolve to the correct IP. I have also checked the configuration of the plug in and can see in my DuckDNS account the dynamic IP address is being updated and the access token is a match.
My network is an Eero Wifi 6. I have set up the rules set for port forwarding in the app as below…
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
# INFO: Using main config file /data/workdir/config
+ Account already registered!
[19:57:15] INFO: OK
***.**.**.34
NOCHANGE
[19:57:15] INFO: Renew certificate for domains: s*******e.duckdns.org and aliases:
Processing s*******e.duckdns.org
+ Checking domain name(s) of existing cert... unchanged.
+ Checking expire date of existing cert...
+ Valid till Jun 5 15:03:57 2024 GMT (Longer than 30 days). Skipping renew!
Just double checked it and yes the IP address in DuckDNS matches with the website you linked.
Interestingly I’ve asked a friend to try my DuckDNS URL and it just hangs for him - doesn’t say not a valid URL or anything. And if I try https://external_IP_address_here but on a connection outside of my wifi, it just hangs too…
So I’ve just set up a really simple http server and set port forwarding to that and I cant access that outside my network, so it looks like this might be an issue with my ISP afterall? It’s annoying because they’ve specifically told me nothing has changed.
I wonder if they are silently blocking inbound 443 perhaps? Maybe change your external port to 8443 (or something like that) and see if it works? That would def sniff out a silent block on ports 80/443.
