Basically what the title says, going to http://hassbian.local:8123 and it can’t connect, however it can connect if I reference the IP on the same port.
Fresh install, so I assume I’m missing something stupid.
Yup, that’s a typo
Is what I get
Well, do you have a DNS server on your network, that is configured to resolve hassbian.local?
If you don’t have one, that’ll be why it’s not working
What does your name resolution? Your router or do you have the machine you’re on set to use something like google dns directly?
Have you verified your hostname?
pi@raspi1:~$ hostname
raspi1
Turns out my DNS was not working well at all on my router so I ended up using ZeroConf instead which is working fine.
Thanks all for the suggestions and help!
