Can't access Hassbian web UI due to the port closed
I followed this tutorial and installed Hassbian seccessfully.
But I still can’t reach the webUI through hassbian.local:8123/ nor ip:8123.
Then I use nmap to scan the ip of that raspberypi, I found that it only opened the port 22.
How to make the port 8123 work?
check the home assistant log file. My guess is that it isn’t actually running.
That only shows Ended unfinished session
I assume you followed this instruction too
If you find that the web page is not reachable after 30 minutes or so, check that you have files in /home/homeassistant/.homeassistant/ , if there are no files in this location then run the installer manually using this command: sudo systemctl start install_homeassistant.service .
