I have a problem with accessing Home Assistant UI (running Hassio) from other computers/tablets than from where I set it up and I can’t seem to find the root cause of it.
What works:
- Accessing https//192.168.10.122:8123 and logging in with username and password from the stationary computer I have
What doesn’t work:
- Accessing https//192.168.10.122:8123 and logging in with username and password from any tablet, mobile phone etc that is on the same network.
- I get to the login screen, enters the same username and password and get the error message “Unable to connect to Home Assistant”. The log shows
2018-12-24 11:57:12 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.10.179
I have duckdns enabled and configured on the Hassio.
I have the RaspberryPI that I am running this on in a basement room and including/excluding z-wave components is hard when you are not in the same room…
