Can't access Home Assistant Green after update to latest 11.4 version
I have a brand new Home Assistant Green and it was working as expected until today I updated via UI to 11.4 version.
After that I lost connection to the device and cannot load the UI on port 8123. I can see the device on my network just cannot load the OS. I do not have backup nor SD card with last functional OS.
What would you recommend?
Thanks for every hint and advice
I have the same issue, although I’m on an x86 NUC. Early research points to a cifs_mount failed w/return code = -101 error, which means the OS starts before the network connection is established.
Just ran the update on RPi 4 and it bricked it… :frowning:
Had the same issue, but after a restart and about a 20 minute wait, it came back up …
same issue. New HA Green, upgrade from 11.2 to 11.4 and its a brick. I just waited about 10 mins and the URL responded eventually.
