I am trying to install hassio using Docker on my ubuntu server, following these instructions
The container is running but I can’t access home assistant at serverip:8123
Are there more steps for setting it up that aren’t in the instructions?
mkdir config
docker run -d -v $PWD/config:/config --net host --name hass \
home-assistant/homeassistant
Should do. You obviously want a running instance of Home Assistant, not a build environment for HASS.io (which is obviously the purpose of above’s Git repository).
Ok, I’ve fixed it
I had lots of different hassio and homeassistant images downloaded which messed everything up in the install. I have deleted all containers and images and run the script again, and its working.
The git repo has the hassio installer in it.
