Hi all - I’ve tried to follow the instructions to set up remote access using NGIX and DuckDNS. I can access home assistant remotely just fine. I can access locally as long as I use HTTPS in a browser and accept the unknown certificate. I cannot access locally via the MacOS app or the iOS app as says the certificate isn’t trusted and I can’t accept it anyway. I thought the reverse proxy was designed to let you access http locally and use https remotely, but I dont appear to be a be able to get the local access working. I assume if I can get the HTTP side of the house working once more my iOS and MacOS apps will work correctly. Thanks for your help.
Here is my config file:
# Loads default set of integrations. Do not remove.
default_config:
# Home Assistant URLs to enable remote access
homeassistant:
external_url: https://mysubdomain.duckdns.org:442
internal_url: http://192.168.1.149:8123
# Certificate details for remote access
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
use_x_forwarded_for: true
trusted_proxies:
- 172.30.33.0/24
ip_ban_enabled: true
login_attempts_threshold: 3
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
