Hi
Atm. i’m on my pc with a wired network access to my network and can access my NAS/VM Home Assistant through homeassistant.local:8132 but not on the static IPv4 172.25.xxx.33:8132.
All wired network connections can access my HA, but when i’m using a device through my WiFi, I get a “ERR_CONNECTION_REFUSED” but my phone through the HA app. did see the IP and connected, and is working, but I can’t open a browser and use IPv4 to the HA or the NetBios name, but I can access my NAS through the static IP to that one through WiFi, so it’s my HA VM that a device on WiFi can’t access atm.
So I can’t see my HA through Google Hub or Alexa Echo, the two devices are on my WiFi and on the same Subnet as my Wired PC.
Can someone guide/help, what that can be the issue here.
(Have tried to turn off firewall on my NAS.)
First check that your wifi access point (might be your router) does not have a wifi segregation enabled or is running the wifi network as a guest network.
Ok I have now turned off the IPv6 on my Homeassistant, and the wired PC is now getting a IPv4 address, but when using a WiFi Laptop and trying to connect, I still get the same error and if I ping homeassistant.local from the laptop, I get a IPv6 address, have made a ipconfig /flushdns, but diden’t help.
