Can't access my instance using public IP
I have an Public IP, and my router is configured to route the packages to my HA instance. But when I try to connect using iOS app and/or Browser, show:
MY_IP refused to connect.
I’m wondering if the HA instance is blocking something from outside, so, if yes… how can I open it?
Thanks!
Hi @MaxK , thanks for your reply, I read the document, but I’m afraid there’s nothing to my case there… I have an public IP and I’m not using Casa Cloud, and I’m trying to access like this:
http//my_ip:8123
https://my_ip:8123
and doesn’t work… it seams the image is not open to receive internet packages
The only way to access from the internet is using Casa Cloud or DuckDNS ?
Given this documentation,
How have you confirmed that your router port forward settings are correct?
Can you access HA from you home network?
@Nick4 Yes, using my computer I can access HA without a problem, even If I connect my iphone using my local ip, I can connect… my problem is using the public IP.
Also, here is my IP rule on my router:
add action=dst-nat chain=dstnat comment=home_assistant dst-port=8123 in-interface=pppoe-imlog=yes log-prefix=HA protocol=tcp to-addresses=10.0.0.6 to-ports=8123
When I try to access the port (using an website to check opened port), I can see the log on my router:
But using browser, ios or ipad to access using the my public IP, I couldn’t see any log
What result (how many hops) do you get when you do a tracert to your public IP address?
After you said about loop I investigated and the problem was on several loops on my ISP… which may cause timeout… I contacted the ISP provider and now works like charm.
Thanks!
