I’m brand new to Home Assistant but wanted to start learning and try it out. I did the Hyper-V install per the instructions but after it finishes installing, I can’t access the UI.
Any of the homeassistant.local URLs don’t work.
ipaddress:4357 works and I get
Supervistor: connected
Supported: supported
Healthy: healthy
ipaddress:8123 doesn’t work and I get a “can’t reach this page”
Any help would be appreciated. Really would like to start learning and playing around with it.
It can take quite a while when you first start Home Assistant … like 5 minutes on a RasPi 4.
And once you get a web page, then another 20-odd minutes while it configures itself. Thank ghod you only have to do it once
I just wiped the hyper-v and started over again with a fresh image and now it’s working. Not sure why it started to work. I tried virtual box and the same thing was happening but it’s working now.
