Can't access via http://hassio.local:8123/ after upgrading SD card
So I recently upgraded my SD card for my HassIO and had no issues flashing my backup onto the card.
I’ve changed no settings my on my Router (still the same Pi and IP address), however for some reason I can no longer connect via http://hassio.local:8123/ and need to connect via my IP xxx.xxx.xxx.xxx:8123
Now obviously it’s not the end of the world if I can’t get the previous connection to work, but I’d like to understand why still :slight_smile:
Reboot your router, or flush the router’s mDNS cache if you know how.
Or fix the HA (Pi) IP Address from the modem/router so you never have to worry about this ever again (Untill you change Pi’s or move to a NUC etc.
Access via http://192.168.0.199:8123 or whatever address you want
