Hey
Im trying to help a friend who has a problem with hers deconz.
She is trying to add a outdoor plug - “Ledvance/Osram Smart+ Plug”
She has tried resetting the device, just plugging in and waiting for 3 minutes, pushing the on/off button i various patterns.
This is her first device she is trying to add and she has no other than this at the moment.
Its a fresh install of both Home Assistant on a Rpi4 and deconz running with a Conbee 2.
She has plugged in the conbee on a usb2-port on the Rpi4 running HA and installed deconz and added path to conbee. She has also updated to the latest firmware inside the deconz/phoscon app.
This was to long ago for me when I installed deconz so I dont remember if you have to authenticate Home Assistant or if you have to do anything else.
Do you need to follow configuration-heading in https://www.home-assistant.io/integrations/deconz/ and add a API-key/add deconz manually before you add a device.
Thanks in advance
