Hi all,
I hope someone can help me as I can’t add a new user in the users section of the configuration. I input the names and passwords then I get an “unknown error”, which in the logs is:
Logger: homeassistant.components.websocket_api.http.connection
Source: auth/providers/homeassistant.py:40
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 23:30:43 (2 occurrences)
Last logged: 23:31:03
[547677266944] Error handling message: Unknown error
File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 18, in _handle_async_response
await func(hass, connection, msg)
File "/usr/src/homeassistant/homeassistant/components/config/auth_provider_homeassistant.py", line 33, in websocket_create
provider = auth_ha.async_get_provider(hass)
File "/usr/src/homeassistant/homeassistant/auth/providers/homeassistant.py", line 40, in async_get_provider
raise RuntimeError("Provider not found")
RuntimeError: Provider not found
I have no idea how long this been a problem as generally my home assistant instance has been stable for ages, but I can’t add a user for the MQTT integration. As far as I have read the websocket api is related to the frontend part of the config yaml and that hasn’t changed.
(I am running the latest hassio on a Pi4 with 8 gb ram if it makes any difference)
thanks for any insight!
