I added a proxy network to my docker container of HA (for integration into traefik).
But if I do this my Sonos isn’t working anymore.
My firewall shows, that there are inputs of the VLAN ID 1.
If I remove this bridge network all is doing well over the VLAN ID 40.
Segmented networks are not officially supported within HA.
HA is designed and expects a flat subnet to work as intended.
This is because every segmented network is different for IP’s and number of segments and firewalls and sharing rules and about 650495849085 other things.
This does not mean you can’t use them or that they can’t be made to work, it means that to get them working you are the support structure on your own subnet(s) and if you are asking for support, you should disclose to the volunteer helping you that this is in use as it often changes the correct answers.
Please keep this in mind when you are trying to do this kind of thing.
