Since upgrading to 0.92.X, my Google Home devices no longer show in the front end.
The first time I upgraded, the UI would not load - systemctl status [email protected] showed that HA was running. One by one I disabled all components, until I discovered that cast: was faulty and preventing the UI from loading.
To debug, I have tried:
- deleting all cast related entries from core.entity_registry, core.config_entries
- commenting out cast: from my yaml, and enabling Cast via Discovery and the Front End, however when I click ‘add Cast’ in the front end, I simply get a spinning blue wheel and can’t go further
- multiple restarts
- ensuring pychromecast is updated to the latest version
- using cast: in combination with host ip of the devices
And so now I’m a bit stuck - any help would be appreciated!
When I run systemctl status [email protected], I can see the following message, which makes me think there is a bug with pychromecast:
CGroup: /system.slice/system-home\x2dassistant.slice/[email protected]
├─25686 /srv/homeassistant/bin/python3 /srv/homeassistant/bin/hass
├─26059 /srv/homeassistant/bin/python3 -m pip install --quiet pychromecast==3.2.1 --upgrade --constraint /srv/homeassistant/lib/python3.5/site-packages/homeassistant/package_constraints.txt
├─26102 /srv/homeassistant/bin/python3 /srv/homeassistant/bin/hass
└─26191 /srv/homeassistant/bin/python3 -m pip install --quiet pychromecast==3.2.1 --upgrade --constraint /srv/homeassistant/lib/python3.5/site-packages/homeassistant/package_constraints.txt
