Can't add devices properly
Hi all gurus,
Having real issues with z-wave after facrory resetting my HA.
Running a z-wave.me shield with antenna on my HA yellow. Before my reset everything worked smooth but now I caadd any devices properly. They adds unsecured and named “node1,2,3…etc” . No manufacturer info and no other info. Tried to exclude and re-add but the issue persist.
Im no developer but the logg looks like I’m having issues. Can anyone please help me decode the logg?
Running z-wave. Js addon in HA
Thx!
Logg:
Logg
Z-Wave JS
· UNKNOWN_FUNC_UNKNOWN_0x98 (0x98)
· FUNC_ID_SERIAL_API_SLAVE_NODE_INFO (0xa0)
· FUNC_ID_ZW_SEND_SLAVE_NODE_INFO (0xa2)
· FUNC_ID_ZW_SET_SLAVE_LEARN_MODE (0xa4)
· FUNC_ID_ZW_GET_VIRTUAL_NODES (0xa5)
· FUNC_ID_ZW_IS_VIRTUAL_NODE (0xa6)
· BridgeApplicationCommand (0xa8)
· SendDataBridge (0xa9)
· SendDataMulticastBridge (0xab)
· UNKNOWN_FUNC_GET_LIBRARY_TYPE (0xbd)
· UNKNOWN_FUNC_SEND_TEST_FRAME (0xbe)
· UNKNOWN_FUNC_GET_PROTOCOL_STATUS (0xbf)
· FUNC_ID_ZW_SET_PROMISCUOUS_MODE (0xd0)
· FUNC_ID_PROMISCUOUS_APPLICATION_COMMAND_HANDLER (0xd1)
· UNKNOWN_FUNC_UNKNOWN_0xD2 (0xd2)
· UNKNOWN_FUNC_UNKNOWN_0xD3 (0xd3)
· UNKNOWN_FUNC_UNKNOWN_0xD4 (0xd4)
· undefined (0xd6)
· Shutdown (0xd9)
· undefined (0xda)
· undefined (0xdb)
· undefined (0xdc)
· undefined (0xdd)
· undefined (0xde)
· undefined (0xdf)
· UNKNOWN_FUNC_ZMEFreqChange (0xf2)
· UNKNOWN_FUNC_ZMEBootloaderFlash (0xf4)
· UNKNOWN_FUNC_ZMECapabilities (0xf5)
· undefined (0xf6)
· undefined (0xf7)
· UNKNOWN_FUNC_ZMESerialAPIOptions (0xf8)
2024-04-11T17:43:33.176Z CNTRLR querying version info…
2024-04-11T17:43:33.226Z CNTRLR received version info:
controller type: Bridge Controller
library version: Z-Wave 7.15
2024-04-11T17:43:33.227Z CNTRLR querying protocol version info…
2024-04-11T17:43:33.251Z CNTRLR received protocol version info:
protocol type: Z-Wave
protocol version: 7.15.4
appl. framework build no.: 256
024-04-11T19:51:16.882Z CNTRLR [Node 004] Timed out while waiting for a response from the node (ZW0201)
2024-04-11T19:51:16.883Z CNTRLR [Node 004] CC version query for Powerlevel timed out - assuming the node suppo
rts version 1…
2024-04-11T19:51:16.884Z CNTRLR » [Node 004] querying the CC version for Association…
2024-04-11T19:51:17.953Z CNTRLR [Node 004] Timed out while waiting for a response from the node (ZW0201)
2024-04-11T19:51:17.954Z CNTRLR [Node 004] CC version query for Association timed out - assuming the node supp
orts version 1…
2024-04-11T19:51:17.956Z CNTRLR » [Node 004] querying the CC version for Multi Channel Association…
2024-04-11T19:51:19.034Z CNTRLR [Node 004] Timed out while waiting for a response from the node (ZW0201)
2024-04-11T19:51:19.036Z CNTRLR [Node 004] CC version query for Multi Channel Association timed out - assuming
the node supports version 1…
2024-04-11T19:51:19.037Z CNTRLR » [Node 004] querying the CC version for Association Group Information…
2024-04-11T19:51:20.110Z CNTRLR [Node 004] Timed out while waiting for a response from the node (ZW0201)
2024-04-11T19:51:20.113Z CNTRLR [Node 004] CC version query for Association Group Information timed out - assu
ming the node supports version 1…
2024-04-11T19:51:20.117Z CNTRLR » [Node 004] querying the CC version for Manufacturer Specific…
2024-04-11T19:51:21.183Z CNTRLR [Node 004] Timed out while waiting for a response from the node (ZW0201)
2024-04-11T19:51:21.184Z CNTRLR [Node 004] CC version query for Manufacturer Specific timed out - assuming the
2024-04-11T19:51:21.185Z CNTRLR » [Node 004] querying the CC version for Device Reset Locally…
2024-04-11T19:51:22.256Z CNTRLR [Node 004] Timed out while waiting for a response from the node (ZW0201)
2024-04-11T19:51:22.257Z CNTRLR [Node 004] CC version query for Device Reset Locally timed out - assuming the
2024-04-11T19:51:22.258Z CNTRLR » [Node 004] querying the CC version for Battery…
2024-04-11T19:51:23.326Z CNTRLR [Node 004] Timed out while waiting for a response from the node (ZW0201)
2024-04-11T19:51:23.327Z CNTRLR [Node 004] CC version query for Battery timed out - assuming the node supports
version 1…
2024-04-11T19:51:23.328Z CNTRLR » [Node 004] querying the CC version for Wake Up…
2024-04-11T19:51:24.456Z CNTRLR [Node 004] Timed out while waiting for a response from the node (ZW0201)
2024-04-11T19:51:24.457Z CNTRLR [Node 004] CC version query for Wake Up timed out - assuming the node supports
version 1…
2024-04-11T19:51:24.458Z CNTRLR » [Node 004] querying the CC version for Binary Sensor…
2024-04-11T19:51:25.532Z CNTRLR [Node 004] Timed out while waiting for a response from the node (ZW0201)
2024-04-11T19:51:25.534Z CNTRLR [Node 004] CC version query for Binary Sensor timed out - assuming the node su
pports version 1…
2024-04-11T19:51:25.535Z CNTRLR » [Node 004] querying the CC version for Notification…
2024-04-11T19:51:26.604Z CNTRLR [Node 004] Timed out while waiting for a response from the node (ZW0201)
2024-04-11T19:51:26.607Z CNTRLR [Node 004] CC version query for Notification timed out - assuming the node sup
ports version 1…
2024-04-11T19:51:26.609Z CNTRLR » [Node 004] querying the CC version for Multilevel Sensor…
2024-04-11T19:51:27.674Z CNTRLR [Node 004] Timed out while waiting for a response from the node (ZW0201)
2024-04-11T19:51:27.674Z CNTRLR [Node 004] CC version query for Multilevel Sensor timed out - assuming the nod
2024-04-11T19:51:27.675Z CNTRLR » [Node 004] querying the CC version for Configuration…
2024-04-11T19:51:28.747Z CNTRLR [Node 004] Timed out while waiting for a response from the node (ZW0201)
2024-04-11T19:51:28.748Z CNTRLR [Node 004] CC version query for Configuration timed out - assuming the node su
pports version 1…
2024-04-11T19:51:28.749Z CNTRLR » [Node 004] querying the CC version for Supervision…
2024-04-11T19:51:29.818Z CNTRLR [Node 004] Timed out while waiting for a response from the node (ZW0201)
2024-04-11T19:51:29.819Z CNTRLR [Node 004] CC version query for Supervision timed out - assuming the node supp
orts version 1…
2024-04-11T19:51:29.823Z CNTRLR » [Node 004] querying the CC version for Firmware Update Meta Data…
2024-04-11T19:51:31.022Z CNTRLR [Node 004] Timed out while waiting for a response from the node (ZW0201)
2024-04-11T19:51:31.023Z CNTRLR [Node 004] CC version query for Firmware Update Meta Data timed out - assuming
2024-04-11T19:51:31.031Z CNTRLR [Node 004] Interviewing Wake Up…
2024-04-11T19:51:31.031Z CNTRLR » [Node 004] retrieving wakeup interval from the device…
2024-04-11T19:51:32.123Z CNTRLR [Node 004] Timed out while waiting for a response from the node (ZW0201)
2024-04-11T19:51:32.124Z CNTRLR » [Node 004] configuring wakeup destination node
2024-04-11T19:51:33.216Z CNTRLR [Node 004] Timed out while waiting for a response from the node (ZW0201)
2024-04-11T19:51:33.221Z CNTRLR [Node 004] wakeup destination node changed!
2024-04-11T19:51:33.238Z CNTRLR [Node 004] Interviewing Z-Wave Plus Info…
2024-04-11T19:51:33.238Z CNTRLR » [Node 004] querying Z-Wave+ information…
2024-04-11T19:51:34.307Z CNTRLR [Node 004] Timed out while waiting for a response from the node (ZW0201)
2024-04-11T19:51:34.311Z CNTRLR [Node 004] Interviewing Battery…
2024-04-11T19:51:34.313Z CNTRLR » [Node 004] querying battery status…
2024-04-11T19:51:35.389Z CNTRLR [Node 004] Timed out while waiting for a response from the node (ZW0201)
2024-04-11T19:51:35.394Z CNTRLR [Node 004] Interviewing Firmware Update Meta Data…
2024-04-11T19:51:35.395Z CNTRLR » [Node 004] Querying firmware update capabilities…
2024-04-11T19:51:36.477Z CNTRLR [Node 004] Timed out while waiting for a response from the node (ZW0201)
2024-04-11T19:51:36.478Z CNTRLR « [Node 004] Firmware update capability query timed out
2024-04-11T19:51:36.483Z CNTRLR [Node 004] Interviewing Association…
2024-04-11T19:51:36.484Z CNTRLR » [Node 004] querying number of association groups…
2024-04-11T19:51:37.565Z CNTRLR [Node 004] Timed out while waiting for a response from the node (ZW0201)
2024-04-11T19:51:37.566Z CNTRLR [Node 004] Querying association groups timed out, skipping interview…
2024-04-11T19:51:37.569Z CNTRLR [Node 004] Interviewing Multi Channel Association…
2024-04-11T19:51:37.570Z CNTRLR » [Node 004] querying number of multi channel association groups…
2024-04-11T19:51:38.646Z CNTRLR [Node 004] Timed out while waiting for a response from the node (ZW0201)
2024-04-11T19:51:38.647Z CNTRLR [Node 004] Querying multi channel association groups timed out, skipping inter
view…
2024-04-11T19:51:38.651Z CNTRLR [Node 004] Interviewing Association Group Information…
2024-04-11T19:51:38.659Z CNTRLR [Node 004] Interviewing Binary Sensor…
2024-04-11T19:51:38.660Z CNTRLR » [Node 004] querying current value…
2024-04-11T19:51:39.734Z CNTRLR [Node 004] Timed out while waiting for a response from the node (ZW0201)
2024-04-11T19:51:39.739Z CNTRLR [Node 004] Interviewing Notification…
2024-04-11T19:51:39.748Z CNTRLR [Node 004] Interviewing Multilevel Sensor…
2024-04-11T19:51:39.749Z CNTRLR » [Node 004] querying current sensor reading…
2024-04-11T19:51:39.811Z CNTRLR [Node 001] does not support CC Multilevel Sensor - discarding received command
2024-04-11T19:51:40.831Z CNTRLR [Node 004] Timed out while waiting for a response from the node (ZW0201)
2024-04-11T19:51:40.837Z CNTRLR [Node 004] Interviewing Configuration…
2024-04-11T19:51:40.840Z CNTRLR [Node 004] ConfigurationCC: skipping interview because CC version is < 3 and t
here is no config file
2024-04-11T19:51:40.844Z CNTRLR [Node 004] Interview stage completed: CommandClasses
2024-04-11T19:51:40.846Z CNTRLR [Node 004] Interview stage completed: OverwriteConfig
2024-04-11T19:51:40.848Z CNTRLR [Node 004] Interview completed
2024-04-11T19:51:40.851Z CNTRLR [Node 004] The node is ready to be used
2024-04-11T19:51:41.120Z CNTRLR » [Node 004] Sending node back to sleep…
2024-04-11T19:51:41.141Z CNTRLR [Node 004] The node is now asleep.
2024-04-11T19:51:43.227Z CNTRLR « [Node 001] received wakeup notification
