I have two aqara temp sensors, 5 aqara weather sensors and a ikea E1743. For no reason the 5 aqara weather sensors and the ikea E1743 become available and I can’t add them again. The two aqara temp sensors was reporting temperature and humidity.
I tried to remove the ZHA integration and add it again with no success. I tried to delete zigbee.db, remove ZHA integration and add it again but also no sucess.
I use the same stick and I noticed I have hard time adding new devices as well. The very first time I setup the CC2531, devices are added and mqtt recognizes it. Later, when I wanted to add new devices, it is a nightmare.
How I do it now is when I want to add new device(s). I shutdown zigbee2Mqtt addon. Physically remove the stick from the usb for a few seconds and connect it back in. Start up zigbee2Mqtt add-on and pair the device(s).
I’ve also have the same issue.
Currently using CC2531 dongle, it was working without issue before.
Today, I tried to change battery of existing device, so I remove the device and tried add again.
No matter how many times I try, it won’t add new device.
I have check the ‘Permit Join’ is enable.
