For some reason I cannot get HA to add an ESPhome device. Have tried starting from scratch multiple times. I create the device in ESPHome, download the config, flash with ESPhome flasher and then when it boots, i can see it working fine in ESPhome dashboard but when i try to add the integration for the entities in HA, it fails with an unknown error. I tried restarting HA multiple times. I also upgraded HA to the latest release. Any help would be appreciated.
Here is the error from HA logs:
Logger: aiohttp.server
Source: helpers/aiohttp_client.py:67
First occurred: 12:09:10 AM (2 occurrences)
Last logged: 12:09:12 AM
Error handling request
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 85, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 80, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 235, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 146, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 180, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 72, in wrapper
result = await method(view, request, data, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 271, in async_configure
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 367, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/esphome/config_flow.py", line 177, in async_step_discovery_confirm
return await self._async_try_fetch_device_info()
File "/usr/src/homeassistant/homeassistant/components/esphome/config_flow.py", line 149, in _async_try_fetch_device_info
and await self._retrieve_encryption_key_from_dashboard()
File "/usr/src/homeassistant/homeassistant/components/esphome/config_flow.py", line 384, in _retrieve_encryption_key_from_dashboard
noise_psk = await dashboard.api.get_encryption_key(device["configuration"])
File "/usr/local/lib/python3.10/site-packages/esphome_dashboard_api/__init__.py", line 103, in get_encryption_key
config = await self.get_config(configuration)
File "/usr/local/lib/python3.10/site-packages/esphome_dashboard_api/__init__.py", line 93, in get_config
return await self.request(
File "/usr/local/lib/python3.10/site-packages/esphome_dashboard_api/__init__.py", line 54, in request
return await resp.json()
File "/usr/src/homeassistant/homeassistant/helpers/aiohttp_client.py", line 67, in json
return await super().json(*args, loads=loads, **kwargs)
File "/usr/local/lib/python3.10/site-packages/aiohttp/client_reqrep.py", line 1120, in json
return loads(stripped.decode(encoding))
orjson.JSONDecodeError: unexpected character: line 1 column 3007 (char 3006)
Additional error:
Logger: aioesphomeapi.connection
Source: runner.py:179
First occurred: 12:09:09 AM (2 occurrences)
192.168.10.125: Connection error occurred: Connection requires encryption
Here is the ESP config:
esphome:
friendly_name: Garage Door
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "XXXXXXXXXX"
ota:
password: "XXXXXXXXX"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Garage-Door Fallback Hotspot"
password: "XXXXXXXXXX"
captive_portal:
binary_sensor:
- platform: gpio
pin:
number: GPIO14
mode: INPUT_PULLUP
inverted: False
device_class: garage_door
name: "Garage Door Car Present"
device_class: presence
lambda: |-
if (id(ultrasonic_sensor1).state < 1.5) {
// car is in the garage
return true;
} else {
// no car
return false;
switch:
- platform: gpio
pin: GPIO12
icon: "mdi:arrow-up-down-bold-outline"
turn_on_action:
- switch.turn_on: relay
- delay: 500ms
- switch.turn_off: relay
- platform: ultrasonic
trigger_pin: GPIO05
echo_pin: GPIO04
name: "Garage Door Car"
update_interval: 30s
filters:
filter_out: nan
timeout: 9m
In ESP device logs:
[00:34:57][W][api.connection:071]: 192.168.10.250: Socket operation failed: BAD_INDICATOR errno=11
