I´m going crazy here… I started using HASS a couple of weeks ago on a Mac Mini and I installed Homebridge and it worked right away. But for different reasons I decided to remove it from the Home-app in my iPhone to start over with a fresh connection, but now I can’t get it working again.
I´m just getting “Home couldn’t connect to this accessory” right away.
I have tested to change “name”, “username” and “pin” in config.json and removed the “persist” and “accessories”-folders but it doesn’t help.
So now I tried to uninstall node.js and homebridge and start over, but that didn’t solved the problem either…
Right now I don’t know what more to try?
Is there any way to debug?
(I have started homebridge with the command “DEBUG=* homebridge -D” but nothing appears in the log when trying to connect)
Make sure that default port 51826 is not blocked, or just simply change for diff one.
I different port solved the issue, thanks!
