Can't add IFTT integration - "An unknown error occurred"
I’m trying to add IFTTT integration from the HA console. I get the “Set up the IFTTT Webhook Applet” pop-up, and when I click Submit I get “Unknown error occurred. Are you sure you want to set up IFTTT?”
The HA log is below. Any idea how I can fix this? I’m running HA 2021.7.4 in a docker container on Lubuntu. I use an SSL connection for HA on the default port 443 (with a LetsEncrypt certificate)
2021-07-31 16:44:28 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
    resp = await self._request_handler(request)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 499, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 119, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 77, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 24, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 78, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 144, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 135, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 155, in post
    return await super().post(request, flow_id)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 63, in wrapper
    result = await method(view, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 109, in post
    result = await self._flow_mgr.async_configure(flow_id, data)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 202, in async_configure
    result = await self._async_handle_step(flow, cur_step["step_id"], user_input)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 260, in _async_handle_step
    result: FlowResult = await getattr(flow, method)(user_input)
  File "/usr/src/homeassistant/homeassistant/helpers/config_entry_flow.py", line 174, in async_step_user
    webhook_url = self.hass.components.webhook.async_generate_url(webhook_id)
  File "/usr/src/homeassistant/homeassistant/components/webhook/__init__.py", line 60, in async_generate_url
    get_url(hass, prefer_external=True, allow_cloud=False),
  File "/usr/src/homeassistant/homeassistant/helpers/network.py", line 116, in get_url
    raise NoURLAvailableError
homeassistant.helpers.network.NoURLAvailableError
@itm1960 Did you ever figure this out? I am getting the same error
No I ditched IFTTT when they decided to introduce subscription charges
I had the same error. The fix for me was to configure an External URL under Configuration, General.
