Hello,i got an error when i want to add a integretion:“Can’t connect to ESP. Please make sure your YAML file contains an ‘api:’ line.”
My yaml look like this:
esphome:
friendly_name: Led
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "some key"
ota:
password: "6d6d74a61f58e398a2405a9dcd0ef51b"
wifi:
ssid: !secret wifi_ssid
#ap:
#ssid: "Led Fallback Hotspot"
#password: "yRoy1boHsQfe"
manual_ip:
# Set this to the IP of the ESP
static_ip: 172.20.10.43
# Set this to the IP address of the router. Often ends with .1
gateway: 172.20.10.1
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
captive_portal:
switch:
- platform: gpio
pin: 2
inverted: true
And i do enter the hostname: led and the port 6053 like in this logs when i installed the yaml on esp32
tom_l
December 7, 2023, 11:00pm
2
Hello and welcome to the forum.
It is very difficult to read your post could you please edit your post and format it correctly as per these instructions: How to help us help you - or How to ask a good question
Sharing your encryption key and password is generally not a good idea. I have removed them. Also you don’t need both an encryption key and password. Just the encryption key will do.
This is the yaml,and i am using iphone hotspot
tom_l
December 8, 2023, 6:21am
4
Please do not post pictures of text. It is impossible for us to copy/edit/paste a solution for you.
done ,srry is first time and i didnt see the performatted text option
tom_l
December 8, 2023, 7:15am
8
Ok that looks good. Can you post the actual error you receive and the full serial log from the esp as text.
i dont get errors from esp:
INFO ESPHome 2023.11.3
INFO Reading configuration /config/esphome/led.yaml...
WARNING GPIO2 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Generating C++ source...
INFO Compiling app...
Processing led (board: esp32dev; framework: arduino; platform: platformio/[email protected] )
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Dependency Graph
|-- AsyncTCP-esphome @ 2.0.1
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.1.0
|-- DNSServer @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- noise-c @ 0.1.4
Compiling .pioenvs/led/src/main.cpp.o
Linking .pioenvs/led/firmware.elf
RAM: [= ] 12.4% (used 40640 bytes from 327680 bytes)
Flash: [===== ] 49.6% (used 910701 bytes from 1835008 bytes)
Building .pioenvs/led/firmware.bin
Creating esp32 image...
Successfully created esp32 image.
esp32_create_combined_bin([".pioenvs/led/firmware.bin"], [".pioenvs/led/firmware.elf"])
Wrote 0xefc00 bytes to file /data/build/led/.pioenvs/led/firmware-factory.bin, ready to flash to offset 0x0
========================= [SUCCESS] Took 47.80 seconds =========================
INFO Successfully compiled program.
esptool.py v4.6.2
Serial port /dev/ttyUSB0
Connecting....
Chip is ESP32-D0WD-V3 (revision v3.0)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: c8:f0:9e:f4:ee:00
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Auto-detected Flash size: 4MB
Flash will be erased from 0x00010000 to 0x000effff...
Flash will be erased from 0x00001000 to 0x00005fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x0000e000 to 0x0000ffff...
Compressed 916480 bytes to 607907...
Wrote 916480 bytes (607907 compressed) at 0x00010000 in 14.0 seconds (effective 522.9 kbit/s)...
Hash of data verified.
Compressed 17440 bytes to 12128...
Wrote 17440 bytes (12128 compressed) at 0x00001000 in 0.5 seconds (effective 256.6 kbit/s)...
Compressed 3072 bytes to 144...
Wrote 3072 bytes (144 compressed) at 0x00008000 in 0.1 seconds (effective 342.2 kbit/s)...
Compressed 8192 bytes to 47...
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 465.0 kbit/s)...
Leaving...
Hard resetting via RTS pin...
INFO Successfully uploaded program.
INFO Starting log output from /dev/ttyUSB0 with baud rate 115200
[09:29:18][I][logger:326]: Log initialized
[09:29:18][C][ota:473]: There have been 5 suspected unsuccessful boot attempts.
[09:29:18][D][esp32.preferences:114]: Saving 1 preferences to flash...
[09:29:18][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[09:29:18][I][app:029]: Running through setup()...
[09:29:18][C][switch.gpio:011]: Setting up GPIO Switch 'Led'...
[09:29:18][D][switch:016]: 'Led' Turning OFF.
[09:29:18][D][switch:055]: 'Led': Sending state OFF
[09:29:18][C][wifi:038]: Setting up WiFi...
[09:29:18][C][wifi:051]: Starting WiFi...
[09:29:18][C][wifi:052]: Local MAC: C8:F0:9E:F4:EE:00
[09:29:18][D][wifi:441]: Starting scan...
[09:29:24][D][wifi:456]: Found networks:
[09:29:24][I][wifi:500]: - 'iPhone - Andrei' [redacted]▂▄▆█
[09:29:24][D][wifi:501]: Channel: 6
[09:29:24][D][wifi:502]: RSSI: -37 dB
[09:29:24][D][wifi:505]: - [redacted] [redacted]▂▄▆█
[09:29:24][I][wifi:286]: WiFi Connecting to 'iPhone - Andrei'...
[09:29:26][D][esp-idf:000]: E (16127) wifi:
[09:29:26][D][esp-idf:000]: Association refused temporarily, comeback time 200 mSec
[09:29:26]
[09:29:26][D][esp-idf:000]: E (16346) wifi:
[09:29:26]
[09:29:26][D][esp-idf:000]: E (16563) wifi:
[09:29:26]
[09:29:26][D][esp-idf:000]: E (16783) wifi:
[09:29:26]
[09:29:36][W][wifi:620]: Connecting to WiFi network failed. Are the credentials wrong?
[09:29:36][W][wifi_esp32:458]: Event: Disconnected ssid='iPhone - Andrei' bssid=[redacted] reason='Handshake Failed'
[09:29:36][W][wifi:604]: Error while connecting to network.
[09:29:36][W][wifi:640]: Restarting WiFi adapter...
[09:29:37][W][wifi_esp32:458]: Event: Disconnected ssid='iPhone - Andrei' bssid=[redacted] reason='Authentication Failed'
[09:29:42][D][wifi:441]: Starting scan...
[09:29:45][D][wifi:456]: Found networks:
[09:29:45][I][wifi:500]: - 'iPhone - Andrei' [redacted]▂▄▆█
[09:29:45][D][wifi:501]: Channel: 6
[09:29:45][D][wifi:502]: RSSI: -35 dB
[09:29:45][D][wifi:505]: - [redacted] [redacted]▂▄▆█
[09:29:45][I][wifi:286]: WiFi Connecting to 'iPhone - Andrei'...
[09:29:47][I][wifi:573]: WiFi Connected!
[09:29:47][C][wifi:391]: Local MAC: C8:F0:9E:F4:EE:00
[09:29:47][C][wifi:396]: SSID: [redacted]
[09:29:47][C][wifi:397]: IP Address: 172.20.10.43
[09:29:47][C][wifi:399]: BSSID: [redacted]
[09:29:47][C][wifi:400]: Hostname: 'led'
[09:29:47][C][wifi:402]: Signal strength: -33 dB ▂▄▆█
[09:29:47][C][wifi:406]: Channel: 6
[09:29:47][C][wifi:407]: Subnet: 255.255.255.0
[09:29:47][C][wifi:408]: Gateway: 172.20.10.1
[09:29:47][C][wifi:409]: DNS1: 0.0.0.0
[09:29:47][C][wifi:410]: DNS2: 0.0.0.0
[09:29:47][C][ota:097]: Over-The-Air Updates:
[09:29:47][C][ota:098]: Address: 172.20.10.43:3232
[09:29:47][C][ota:101]: Using Password.
[09:29:47][W][ota:107]: Last Boot was an unhandled reset, will proceed to safe mode in 5 restarts
[09:29:47][C][api:025]: Setting up Home Assistant API server...
[09:29:47][I][app:062]: setup() finished successfully!
[09:29:47][I][app:102]: ESPHome version 2023.11.3 compiled on Dec 8 2023, 09:28:23
[09:29:47][C][wifi:559]: WiFi:
[09:29:47][C][wifi:402]: Signal strength: -34 dB ▂▄▆█
[09:29:47][C][logger:416]: Logger:
[09:29:47][C][logger:417]: Level: DEBUG
[09:29:47][C][logger:418]: Log Baud Rate: 115200
[09:29:47][C][logger:420]: Hardware UART: UART0
[09:29:47][C][switch.gpio:068]: GPIO Switch 'Led'
[09:29:47][C][switch.gpio:076]: Inverted: YES
[09:29:47][C][switch.gpio:091]: Restore Mode: always OFF
[09:29:47][C][switch.gpio:031]: Pin: GPIO2
[09:29:47][C][captive_portal:088]: Captive Portal:
[09:29:47][C][mdns:115]: mDNS:
[09:29:47][C][mdns:116]: Hostname: led
[09:29:47][C][api:139]: API Server:
[09:29:47][C][api:140]: Address: 172.20.10.43:6053
[09:29:47][C][api:142]: Using noise encryption: YES
the only error is when i try to add integresion:
tom_l
December 8, 2023, 7:37am
10
Enter the IP address of your esp under “Host”, 172.20.10.43
i can only insert ports,not the full adress,or you reffer in the yaml file?
tom_l
December 8, 2023, 10:19am
12
Add this is to your configuration.yaml file and restart home assistant.
api:
It will auto-discover your device once restarted. Then all you may need to add is the encryption key.
armin-gh
(ArminH)
December 8, 2023, 10:20am
13
You wrote somewhere that you are using your iPhone as Hotspot?
is your device running HA connected with the same Hotspot? And even then I have some doubts the iPhone Hotspot allows communication between devices.
Armin
so you are saying is impossibile with hotspot?
yes is on hotspot,i had problems with it but i manage to overcome them but now the problem is that i cannot introduce integretion even thogh i have an api line
armin-gh
(ArminH)
December 8, 2023, 11:44am
17
you have not provided details about the device where you are running HA, but yes, to my best knowledge, what you are trying to achieve is not possible with an iPhone Hotspot, even if all devices (HA- and the ESPHome-Device) are connected to the same hotspot, they can’t “see” each other
Armin
so the api line already was i deleted i entered a new one,loded the yaml and retsart HA but it doesn’t show me the integresion and i got the same problem when i try to add it manually
esphome:
friendly_name: Led
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
api:
ota:
password: "4756ddca14fb16eac55fa40ced768076"
wifi:
#ap:
manual_ip:
static_ip: 172.20.10.80
captive_portal:
switch:
- platform: gpio
pin: 2
inverted: true
tom_l
December 8, 2023, 12:15pm
19
Add it to your configuration.yaml file as well as your esphome device file.
But that probably wont help because:
NathanCu
(Nathan Curtis)
December 8, 2023, 12:16pm
20
Thays exactly what they’re saying.
The Hotspot is not a normal network. Clients are isolated and cannot see each other, meaning fundamental network connectivity is not possible - and this will never work
You need basic network connectivity first.
