Cant add Multiple switches to Dashboard
I’m currently using arduino to control relays through out my house which i have currently working however, upon attempting to add a second switch home assistant throws up the error:
" Configuration invalidCHECK CONFIG
Error loading /config/configuration.yaml: while parsing a block mapping in “/config/configuration.yaml”, line 1, column 1 expected <block end>, but found ‘<block mapping start>’ in “/config/configuration.yaml”, line 92, column 2"
I’ve tried researching online and looking at similar forum posts but I’ve not been able to fix it.
Below is my configuration.yaml:
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: 0
  longitude: 0
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 0
  # metric for Metric, imperial for Imperial
  unit_system: metric
  # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
  time_zone: UTC
  # Customization file
  customize: !include customize.yaml
# Show links to resources in log and frontend
#introduction:
# Enables the frontend
frontend:
  themes: !include themes.yaml
# Enables configuration UI
config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
#   base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
  # Optional, allows Home Assistant developers to focus on popular components.
  # include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Sensors
  # Weather prediction
  - platform: yr
# Text to speech
tts:
  - platform: google
# Cloud
cloud:
#Xbox
media_player:
  - platform: xboxone
    device: FD001DEF26E50A75
# Arduino
arduino:
  port: /dev/ttyACM0
# Relay
switch:
  platform: arduino
  pins:
    6:
    12:
      initial: true
      negate: true
#Xbox One switch
 switch 2:
    switches:
      xboxone:
        friendly_name: Xbox One
        value_template: "{{ is_state('media_player.living_room_xbox_one', 'on') }}"
        turn_on:
          service: media_player.turn_on
            entity_id: media_player.living_room_xbox_one
        turn_off:
          service: media_player.turn_off
#Ios
ios:
group: !include groups.yaml
script: !include scripts.yaml
