I am trying to add new Matter devices to Home Assistant with my Apple TV 4K 2022 as Thread Border Router but I always get an error saying "Thread Border Router required on your network" or something like that.
It's important to mention that if I add the devices to Apple Home first, then I can add it to Home Assistant using the pairing code from Apple Home. But I can't use the Home Assistant app for comissioning.
Home Assistant doesn't have a Thread dongle but I'm under the impression that if the Apple TV's Thread network is set to "Preferred network" then I should be able to comission new devices into HA without first going through Apple Home?
I have sent credentials to Home Assistant in the HA companion app and I have set my Apple TV network as the preferred network. There are no other available networks.
However, right this moment I have not clicked the three dots on the preferred network and chosen "Use router for Android + iOS credentials" because when I did that the last three times it made an error appear every time I try to commission a new device, something like "Thread network credentials does not match with any of the active thread networks around".
Any help to solve this is greatly appreciated!
Edit: I should add that there is only one entry under Companion app > Debugging > Thread and I cannot remove it. If I try to remove it nothing happens and it never goes away.
