Can't add previously used Zooz switch
Hi all,
I’m having trouble adding a light switch previously added before I rolled back to a snapshot. I nuked my setup and started again because of an unrelated problem described here:
https://community.home-assistant.io/t/yale-smart-lock/23539/15
After I successfully added a GE switch I tried adding my second switch, a Zooz switch.
Here is the OZW log:
2020-01-04 20:07:37.906 Detail, Queuing (Controller) Add Device
2020-01-04 20:07:37.907 Info, Add Device
2020-01-04 20:07:37.907 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x13, 0x62
2020-01-04 20:07:37.907 Detail, Notification: ControllerCommand - Starting
2020-01-04 20:07:37.908 Info, contrlr, Sending (Command) message (Callback ID=0x13, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x13, 0x62
2020-01-04 20:07:37.911 Detail, contrlr,   Received: 0x01, 0x07, 0x00, 0x4a, 0x13, 0x01, 0x00, 0x00, 0xa0
2020-01-04 20:07:37.911 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2020-01-04 20:07:37.911 Info, contrlr, ADD_NODE_STATUS_LEARN_READY
2020-01-04 20:07:37.911 Detail, Node001,   Expected callbackId was received
2020-01-04 20:07:37.912 Detail, Node001,   Expected reply was received
2020-01-04 20:07:37.912 Detail, Node001,   Message transaction complete
2020-01-04 20:07:37.912 Detail, contrlr, Removing current message
2020-01-04 20:07:37.912 Detail, Notification: ControllerCommand - Waiting
2020-01-04 20:07:37.913 Info, WriteNextMsg Controller nothing to do
2020-01-04 20:07:50.511 Detail, Node006,   Received: 0x01, 0x0b, 0x00, 0x04, 0x10, 0x06, 0x03, 0x20, 0x03, 0xff, 0xbc, 0x00, 0x85
2020-01-04 20:07:52.273 Detail, Node006,   Received: 0x01, 0x0b, 0x00, 0x04, 0x10, 0x06, 0x03, 0x20, 0x03, 0xff, 0xbc, 0x00, 0x85
2020-01-04 20:09:22.320 Detail, Node006,   Received: 0x01, 0x0b, 0x00, 0x04, 0x10, 0x06, 0x03, 0x20, 0x03, 0xff, 0xbc, 0x00, 0x85
2020-01-04 20:09:22.321 Detail,
2020-01-04 20:09:23.580 Detail, Node006,   Received: 0x01, 0x0b, 0x00, 0x04, 0x10, 0x06, 0x03, 0x20, 0x03, 0xff, 0xb6, 0x00, 0x8f
Note that HA and my USB gateway must be seeing the switch because every time I press up on the switch it writes these lines to the log:
Any help would be appreciated
-Frozear
