Can't add remote to Homekit as accessory
I’m trying to add my android TV remote instance into HomeKit and cannot get it to add successfully.
The remote works great within HA so I know there is no issue there.
I’ve tried adding it in the UI by creating a new configuration, including remote instance and using as accessory. When I do this, it creates a phantom bridge and a separate accessory instance for the android TV device (chromecast) but it says configuration fails.
I tried adding it via YAML and get the same error as I did when trying to create the remote accessory via UI:
Logger: homeassistant
Source: components/homekit/type_remotes.py:150
First occurred: 2:05:49 PM (1 occurrences)
Last logged: 2:05:49 PM
Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/components/homekit/__init__.py", line 793, in async_start
    if not await self._async_create_accessories():
  File "/usr/src/homeassistant/homeassistant/components/homekit/__init__.py", line 977, in _async_create_accessories
    acc = self._async_create_single_accessory(entity_states)
  File "/usr/src/homeassistant/homeassistant/components/homekit/__init__.py", line 906, in _async_create_single_accessory
    acc = get_accessory(self.hass, self.driver, state, STANDALONE_AID, conf)
  File "/usr/src/homeassistant/homeassistant/components/homekit/accessories.py", line 259, in get_accessory
    return TYPES[a_type](hass, driver, name, state.entity_id, aid, config)
  File "/usr/src/homeassistant/homeassistant/components/homekit/type_remotes.py", line 223, in __init__
    super().__init__(
  File "/usr/src/homeassistant/homeassistant/components/homekit/type_remotes.py", line 101, in __init__
    sources = self._get_ordered_source_list_from_state(state)
  File "/usr/src/homeassistant/homeassistant/components/homekit/type_remotes.py", line 162, in _get_ordered_source_list_from_state
    return list(self._get_mapped_sources(state))
  File "/usr/src/homeassistant/homeassistant/components/homekit/type_remotes.py", line 150, in _get_mapped_sources
    self._mapped_sources = {
TypeError: 'NoneType' object is not iterable
My YAML code is:
Homekit.yaml:
- name: ChromecastTest
  port: 21611
  mode: accessory
  filter:
    include_entities:
       - remote.chromecast
Any suggestions?
Thanks!
