Hi, I can’t add Repository link to hacs addon
This is error that I’ve when I try to add Repository link:
How I can fix it?
Tnks.
calisro
(Rob)
July 13, 2022, 8:04pm
2
Those are regular addons. Not HACS. Add them in the home assistant addons.
Sorry I’m a newbie I can’t add Repository link
Home Assistant Community Add-ons
I can’t upload installed add-on
I can’t download new add-on
calisro
(Rob)
July 13, 2022, 8:23pm
4
Those addons you referenced are already part of HA. You jsut need to go to:
Settings → Add-Ons → Store and install them. you don’t need to install the repository link to install those unless they are actually missing… Then you could add ‘https://github.com/hassio-addons/repository ’ but you shouldn’t need to.
Ok thanks but I can’t se any add on
calisro
(Rob)
July 13, 2022, 8:41pm
6
This showed addons. Can you click them and install what you want? Do you get an error?
This is installed Add-ons, I can’t update them, I can’t install further.
Problem is the same as this:
opened 02:49PM - 19 May 22 UTC
closed 09:40AM - 20 May 22 UTC
bug
### Describe the issue you are experiencing
Core add-ons are missing except fro… m those that were installed when home assisstant itself was installed.
Icons of those add-ons are missing too.
When manually checking add-ons for updates, errors are logged in supervisor log.
This issue is a blocker for me, because there is no way for me to install mosquitto broker and given that I can't use Zigbee2mqtt.
Core add-ons that are installed don't get updated.
### What is the used version of the Supervisor?
supervisor-2022.05.2
### What type of installation are you running?
Home Assistant OS
### Which operating system are you running on?
Home Assistant Operating System
### What is the version of your installed operating system?
5.15.38
### What version of Home Assistant Core is installed?
core-2022.5.5
### Steps to reproduce the issue
1. Go to Settings > Add-ons;
2. Click "Add-on store" button bottom right of the screen;
3. Click three dots top right of the screen;
4. Select "Check for updates" from drop list;
5. Check Supervisor log for errors.
### Anything in the Supervisor logs that might be useful for us?
```txt
Full logs
AssertionError: Remote 'origin' has no refspec set.
You can set it as follows: 'git config --add "remote.origin.fetch +refs/heads/*:refs/heads/*"'.
File "/usr/src/supervisor/supervisor/store/repository.py", line 110, in update
await self.git.pull()
File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 112, in wrapper
raise JobException() from err
supervisor.exceptions.JobException
22-05-19 15:46:30 INFO (MainThread) [supervisor.store] Loading add-ons from store: 42 all - 0 new - 0 remove
22-05-19 16:04:45 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-05-19 16:20:09 INFO (MainThread) [supervisor.host.info] Updating local host information
22-05-19 16:20:10 INFO (MainThread) [supervisor.host.services] Updating service information
22-05-19 16:20:10 INFO (MainThread) [supervisor.host.network] Updating local network information
22-05-19 16:20:10 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-05-19 16:20:10 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-05-19 16:35:29 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-05-19 16:44:32 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-05-19 16:44:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-05-19 16:44:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-05-19 16:44:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-05-19 16:44:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-05-19 16:44:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
22-05-19 16:44:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
22-05-19 16:44:32 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-05-19 16:44:32 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-05-19 16:44:32 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-05-19 16:44:32 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-05-19 16:44:32 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
22-05-19 17:06:16 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-05-19 17:37:04 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-05-19 17:41:35 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
22-05-19 17:41:35 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
22-05-19 17:41:35 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
22-05-19 17:41:35 ERROR (MainThread) [supervisor.jobs] Unhandled exception: Remote 'origin' has no refspec set.
File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 106, in wrapper
return await self._method(*args, **kwargs)
File "/usr/src/supervisor/supervisor/store/git.py", line 155, in pull
await self.sys_run_in_executor(
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.9/site-packages/git/remote.py", line 876, in fetch
self._assert_refspec()
File "/usr/local/lib/python3.9/site-packages/git/remote.py", line 835, in _assert_refspec
raise AssertionError(msg % (self.name, self.name))
22-05-19 17:41:39 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-102028' coro=<Repository.update() done, defined at /usr/src/supervisor/supervisor/store/repository.py:106> exception=JobException()>
22-05-19 17:41:39 INFO (MainThread) [supervisor.store] Loading add-ons from store: 42 all - 0 new - 0 remove
### Additional information
I saw other HA users having this very problem, but there was very little if no effort form HA developers to try and address this issue.
Would be nice to finally get proper help and the solution.
daath
(Lars G P)
May 28, 2023, 8:34pm
8
I am getting this error as well. I can see official addons, and a few add-ons that I added myself (ESPHome, Grott, Samba backup) - but there are no Community Add-ons - and when I try to add, it says it’s already there - but obviously not. I can’t install Node-RED …
