Can't add sensors with ConBee 2
Hello everybody,
I have a problem with my Conbe2, can’t add any xiaomi device.
This my config :
Raspi 3 b+
SSD on a X850
HassOS 4.11 (fresh install)
deCONZ V6.2.3
ConBee 2
Sensor temp Xiaomy and move detector Xiaomy
Hardware :
Hardware
  • serial:
    • /dev/ttyAMA0
    • /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2216346-if00
    • /dev/ttyACM0
  • input:
  • disk:
  • gpio:
    • gpiochip0
    • gpiochip504
    • gpiochip100
  • audio:
    • 0:
      • name: bcm2835_alsa - bcm2835 ALSA
      • type: ALSA
      • devices:
        • [object Object]
        • [object Object]
        • [object Object]
deCONZ config :
device: /dev/ttyACM0
logger:
default: info
logs:
pydeconz: debug
homeassistant.components.deconz: debug
configuration.yaml :
default_config:
tts:
  • platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
discovery:
In the deCONZ configuration, i have tried :
/dev/ttyAMA0
and
/dev/ttyACM0
The problem is the same.
When I go to the webui (phoscon), I can see my ConBee 2 with the ip of my Home Assistant, I click on it and I log in and at the top right it says “Phoscon-GW 172.30.33.1”.
When I go to the menu, then to the gateway, I can clearly see my ConBee which is detected.
When I try to add a sensor it does not find anything, here are the logs of deCONZ:
172.30.32.2 - - [30/Jul/2020:17:55:24 +0000] “GET /api/9C44754BEF/lights HTTP/1.1” 200 317 “http://192.168.1.39:8123/api/hassio_ingress/Lvin2sAQYubHQ94ABn2hEOa1OJU6MG-6XnhEPKYv5dU/pwa/devices-sensors.html?_v=4154ad416996058bda9ab2d1af622fe5bef45cec,6,4,19&gwid=00212EFFFF05DB27” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.89 Safari/537.36”
172.30.32.2 - - [30/Jul/2020:17:55:24 +0000] “GET /api/9C44754BEF/sensors/new?=1596131709386 HTTP/1.1" 200 36 “http://192.168.1.39:8123/api/hassio_ingress/Lvin2sAQYubHQ94ABn2hEOa1OJU6MG-6XnhEPKYv5dU/pwa/devices-sensors.html?_v=4154ad416996058bda9ab2d1af622fe5bef45cec,6,4,19&gwid=00212EFFFF05DB27” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.89 Safari/537.36”
172.30.32.2 - - [30/Jul/2020:17:55:25 +0000] "GET /api/9C44754BEF/sensors/new?
=1596131709387 HTTP/1.1” 200 36 “http ://192.168.1.39:8123/api/hassio_ingress/Lvin2sAQYubHQ94ABn2hEOa1OJU6MG-6XnhEPKYv5dU/pwa/devices-sensors.html?v=4154ad416996058bda9ab2d1af622fe5bef45cec,6,4,19&gwid=00212EFFFF05DB27" “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.89 Safari/537.36”
=1596131709388 HTTP/1.1” 200 36 “http ://192.168.1.39:8123/api/hassio_ingress/Lvin2sAQYubHQ94ABn2hEOa1OJU6MG-6XnhEPKYv5dU/pwa/devices-sensors.html?v=4154ad416996058bda9ab2d1af622fe5bef45cec,6,4,19&gwid=00212EFFFF05DB27" “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.89 Safari/537.36”
172.30.32.2 - - [30/Jul/2020:17:55:26 +0000] "GET /api/9C44754BEF/sensors/new?
=1596131709389 HTTP/1.1” 200 36 “http ://192.168.1.39:8123/api/hassio_ingress/Lvin2sAQYubHQ94ABn2hEOa1OJU6MG-6XnhEPKYv5dU/pwa/devices-sensors.html?v=4154ad416996058bda9ab2d1af622fe5bef45cec,6,4,19&gwid=00212EFFFF05DB27" “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.89 Safari/537.36”
=1596131709390 HTTP/1.1” 200 36 “http ://192.168.1.39:8123/api/hassio_ingress/Lvin2sAQYubHQ94ABn2hEOa1OJU6MG-6XnhEPKYv5dU/pwa/devices-sensors.html?v=4154ad416996058bda9ab2d1af622fe5bef45cec,6,4,19&gwid=00212EFFFF05DB27" “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.89 Safari/537.36”
172.30.32.2 - - [30/Jul/2020:17:55:27 +0000] "GET /api/9C44754BEF/sensors/new?
=1596131709391 HTTP/1.1” 200 36 “http ://192.168.1.39:8123/api/hassio_ingress/Lvin2sAQYubHQ94ABn2hEOa1OJU6MG-6XnhEPKYv5dU/pwa/devices-sensors.html?v=4154ad416996058bda9ab2d1af622fe5bef45cec,6,4,19&gwid=00212EFFFF05DB27" “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.89 Safari/537.36”
=1596131709392 HTTP/1.1” 200 36 “http ://192.168.1.39:8123/api/hassio_ingress/Lvin2sAQYubHQ94ABn2hEOa1OJU6MG-6XnhEPKYv5dU/pwa/devices-sensors.html?v=4154ad416996058bda9ab2d1af622fe5bef45cec,6,4,19&gwid=00212EFFFF05DB27" “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.89 Safari/537.36”
172.30.32.2 - - [30/Jul/2020:17:55:28 +0000] "GET /api/9C44754BEF/sensors/new?
=1596131709393 HTTP/1.1” 200 36 “http ://192.168.1.39:8123/api/hassio_ingress/Lvin2sAQYubHQ94ABn2hEOa1OJU6MG-6XnhEPKYv5dU/pwa/devices-sensors.html?v=4154ad416996058bda9ab2d1af622fe5bef45cec,6,4,19&gwid=00212EFFFF05DB27" “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.89 Safari/537.36”
=1596131709394 HTTP/1.1” 200 36 “http ://192.168.1.39:8123/api/hassio_ingress/Lvin2sAQYubHQ94ABn2hEOa1OJU6MG-6XnhEPKYv5dU/pwa/devices-sensors.html?v=4154ad416996058bda9ab2d1af622fe5bef45cec,6,4,19&gwid=00212EFFFF05DB27" “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.89 Safari/537.36”
172.30.32.2 - - [30/Jul/2020:17:55:29 +0000] "GET /api/9C44754BEF/sensors/new?
=1596131709395 HTTP/1.1” 200 36 “http ://192.168.1.39:8123/api/hassio_ingress/Lvin2sAQYubHQ94ABn2hEOa1OJU6MG-6XnhEPKYv5dU/pwa/devices-sensors.html?v=4154ad416996058bda9ab2d1af622fe5bef45cec,6,4,19&gwid=00212EFFFF05DB27" “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.89 Safari/537.36”
172.30.32.2 - - [30/Jul/2020:17:55:29 +0000] "GET /api/9C44754BEF/sensors?
=1596131709396 HTTP/1.1” 200 329 “http ://192.168.1.39:8123/api/hassio_ingress/Lvin2sAQYubHQ94ABn2hEOa1OJU6MG-6XnhEPKYv5dU/pwa/devices-sensors.html?v=4154ad416996058bda9ab2d1af622fe5bef45cec,6,4,19&gwid=00212EFFFF05DB27" “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.89 Safari/537.36”
=1596131709397 HTTP/1.1” 200 36 “http ://192.168.1.39:8123/api/hassio_ingress/Lvin2sAQYubHQ94ABn2hEOa1OJU6MG-6XnhEPKYv5dU/pwa/devices-sensors.html?v=4154ad416996058bda9ab2d1af622fe5bef45cec,6,4,19&gwid=00212EFFFF05DB27" “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.89 Safari/537.36”
172.30.32.2 - - [30/Jul/2020:17:55:30 +0000] "GET /api/9C44754BEF/sensors/new?
=1596131709398 HTTP/1.1” 200 36 “http ://192.168.1.39:8123/api/hassio_ingress/Lvin2sAQYubHQ94ABn2hEOa1OJU6MG-6XnhEPKYv5dU/pwa/devices-sensors.html?v=4154ad416996058bda9ab2d1af622fe5bef45cec,6,4,19&gwid=00212EFFFF05DB27" “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.89 Safari/537.36”
172.30.32.2 - - [30/Jul/2020:17:55:31 +0000] "GET /api/9C44754BEF/sensors/new?
=1596131709399 HTTP/1.1” 200 36 “http ://192.168.1.39:8123/api/hassio_ingress/Lvin2sAQYubHQ94ABn2hEOa1OJU6MG-6XnhEPKYv5dU/pwa/devices-sensors.html?v=4154ad416996058bda9ab2d1af622fe5bef45cec,6,4,19&gwid=00212EFFFF05DB27" “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.89 Safari/537.36”
172.30.32.2 - - [30/Jul/2020:17:55:32 +0000] "GET /api/9C44754BEF/sensors/new?
=1596131709400 HTTP/1.1” 200 36 “http ://192.168.1.39:8123/api/hassio_ingress/Lvin2sAQYubHQ94ABn2hEOa1OJU6MG-6XnhEPKYv5dU/pwa/devices-sensors.html?v=4154ad416996058bda9ab2d1af622fe5bef45cec,6,4,19&gwid=00212EFFFF05DB27" “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.89 Safari/537.36”
172.30.32.2 - - [30/Jul/2020:17:55:33 +0000] "GET /api/9C44754BEF/sensors/new?
=1596131709401 HTTP/1.1” 200 36 “http ://192.168.1.39:8123/api/hassio_ingress/Lvin2sAQYubHQ94ABn2hEOa1OJU6MG-6XnhEPKYv5dU/pwa/devices-sensors.html?v=4154ad416996058bda9ab2d1af622fe5bef45cec,6,4,19&gwid=00212EFFFF05DB27" “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.89 Safari/537.36”
172.30.32.2 - - [30/Jul/2020:17:55:34 +0000] "GET /api/9C44754BEF/sensors/new?
=1596131709402 HTTP/1.1” 200 36 “http ://192.168.1.39:8123/api/hassio_ingress/Lvin2sAQYubHQ94ABn2hEOa1OJU6MG-6XnhEPKYv5dU/pwa/devices-sensors.html?_v=4154ad416996058bda9ab2d1af622fe5bef45cec,6,4,19&gwid=00212EFFFF05DB27” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.89 Safari/537.36”
I tried to start again from scratch but nothing helped.
When I plug my ConBee into my PC and launch the webui via the Deconz application, I can see the correct ip at the top right and I can add sensors.
Do you have any idea to solve my problem.
Thank you in advance.
I’m having the same issue , I don’t have a solution. My installation is on a NUC.
Exactly the same issue here…
I have the Aoetec Z-Wave and the ConBee stick on a powered hub connected to a Pi 4. I was wondering if there was an issue with that configuration but from what I was able to read, this seems to a rather typical setup.
And the answer (in my case was)…
don’t connect the ConBee to a USB3 output. USB2 works fine.
Hello, I fixed that issue after reading that Conbee II stick USB is having interference with SSD.
When I take away the SDD from the Conbee II Stick with an extension cable, it did recognize the sensors.
Hi!,
I’ve been added sensors sucessfully with SSD drive, changing conbee from USB3.0 to the others USB, and changing zigbee channel to 20
I always though the interference is caused by USB controller chips, not by SSD. So the way was to move the zigbee stick away from rPI
