I started porting my scenes from Hue to Home Assistant. Main reason is that I started adding lights, that are not part of Hue.
However, when I add my Exhaust Hood light (Home Connect) under “Entities”, it will not just add the light entity but put the whole device under devices. I do not want that as it has side effects: When the hood is already running and I start the scene to adjust the light, the hood will stop as it was off when the whole device was captured where I only wanted that entity.
So right now the only way to accomplish this seems to be a script instead of a scene, as the scene only wants the full device (or entities that dont have a device). Why?
This is making scenes kind of useless to me, because when I start using a script for one scene, it would only make sense to screw scenes at all and use Skipts everywhere to have a consistent setup that allows for flawless automations (needless to say that it really sucks when creating an automation and sometimes you have a script for a scene and sometimes a scene).
Best regards
