I’m having trouble adding a tuya LED strip to hass.io. I previously had a tuya light (smart_lifte platform) but the light died. I didn’t remove it for a couple of weeks and kept getting errors that the tuya component couldn’t be loaded. I then got a replacement for it and tried to add it back to home assistant. Now I can’t get it to add. I don’t get anything in the logs and tuya.force_update or tuya.pull_devices doesn’t do anything. I’m not sure what to try now. Is there a way to reset the tuya component (besides removing and re-adding it to my configuration file)? Thank you.
