Background:
New house using existing HA setup, although I upgraded the ZWave controller to Connect ZWA-2. All the old ZWave devices and entities are no longer listed, but I cant get any of them to pair. even having a Monoprice plug 2 feet from the antenna won’t successfully adopt. I have tried the Exclusion process as well, but that fails.
I double checked the ZWave-JS and it is attached to the ZWA-2 which is plugged into a powered USB HUB.
Any thoughts on next steps?
System Information
Installation method: Home Assistant OS
Core:2025.7.4
Supervisor:2025.11.4
Operating System: 16.0
Frontend20250702.3
ZWave info:
Driver version:15.15.0
Server version:3.4.0
Home ID:3241320076
Server URL:ws://core-zwave-js:3000
Log before and after pressing add device:
Subscribed to Z-Wave JS log messages…
Log level changed to: Verbose
2025-11-20 15:46:08.085 DRIVER one or more queues busy
2025-11-20 15:46:08.087 DRIVER » [REQ] [GetBackgroundRSSI]
2025-11-20 15:46:08.096 DRIVER « [RES] [GetBackgroundRSSI]
channel 0: -112 dBm
channel 1: -114 dBm
channel 2: -114 dBm
channel 3: -107 dBm
2025-11-20 15:46:08.100 DRIVER all queues idle
2025-11-20 15:46:38.085 DRIVER one or more queues busy
2025-11-20 15:46:38.086 DRIVER » [REQ] [GetBackgroundRSSI]
2025-11-20 15:46:38.094 DRIVER « [RES] [GetBackgroundRSSI]
channel 0: -112 dBm
channel 1: -107 dBm
channel 2: -107 dBm
channel 3: -107 dBm
2025-11-20 15:46:38.096 DRIVER all queues idle
2025-11-20 15:46:49.941 CNTRLR Starting inclusion process with strategy Default...
2025-11-20 15:46:49.945 DRIVER one or more queues busy
2025-11-20 15:46:49.948 DRIVER » [REQ] [AddNodeToNetwork]
node type: Any
high power: true
network wide: true
callback id: 83
2025-11-20 15:46:49.960 DRIVER « [REQ] [AddNodeToNetwork]
status: Ready
callback id: 83
2025-11-20 15:46:49.961 CNTRLR The controller is now ready to add nodes
2025-11-20 15:46:49.963 DRIVER all queues idle
2025-11-20 15:46:51.049 CNTRLR stopping inclusion process...
2025-11-20 15:46:51.052 DRIVER one or more queues busy
2025-11-20 15:46:51.053 DRIVER » [REQ] [AddNodeToNetwork]
action: Stop
high power: true
network wide: true
callback id: 84
2025-11-20 15:46:51.062 DRIVER « [REQ] [AddNodeToNetwork]
status: Done
callback id: 84
2025-11-20 15:46:51.064 CNTRLR The inclusion process was stopped
2025-11-20 15:46:51.067 DRIVER all queues idle
2025-11-20 15:46:55.027 CNTRLR Starting inclusion process with strategy Security_S0...
2025-11-20 15:46:55.030 DRIVER one or more queues busy
2025-11-20 15:46:55.032 DRIVER » [REQ] [AddNodeToNetwork]
node type: Any
high power: true
network wide: true
callback id: 85
2025-11-20 15:46:55.041 DRIVER « [REQ] [AddNodeToNetwork]
status: Ready
callback id: 85
2025-11-20 15:46:55.043 CNTRLR The controller is now ready to add nodes
2025-11-20 15:46:55.046 DRIVER all queues idle
2025-11-20 15:47:08.084 DRIVER one or more queues busy
2025-11-20 15:47:08.086 DRIVER » [REQ] [GetBackgroundRSSI]
2025-11-20 15:47:08.093 DRIVER « [RES] [GetBackgroundRSSI]
channel 0: -112 dBm
channel 1: -114 dBm
channel 2: -114 dBm
channel 3: -107 dBm
2025-11-20 15:47:08.095 DRIVER all queues idle
