Can't attach static image from webcam to telegram using Dlink DCS-935L
I got lucky today at my local Staples and snagged two Dlink DCS-935L IP Cameras. I have them up and running, and I can see them in HA with a static image that is changed every 10 seconds using the generic MJPEG stream. I am now trying to add Telegram in, as one of the webcams I have in my porch and would like it to send a message/picture when my doorbell is pressed. I have the automation working, and can successfully send a text only notification with Telegram and syncs to my devices. But, when I try to add the photo, I get this error in my HA log:
16-09-10 19:35:23 homeassistant.core: BusHandler:Exception doing job
  File "/home/hass/.homeassistant/deps/telegram/inputfile.py", line 90, in __init__
    self.mimetype = InputFile.is_image(self.input_file_content)
  File "/home/hass/.homeassistant/deps/telegram/inputfile.py", line 170, in is_image
    raise TelegramError('Could not parse file content')
telegram.error.TelegramError: Could not parse file content
  File "/srv/hass/lib/python3.5/site-packages/homeassistant/core.py", line 852, in job_handler
    func(*args)
  File "/srv/hass/lib/python3.5/site-packages/homeassistant/core.py", line 717, in _execute_service
    service(call)
  File "/srv/hass/lib/python3.5/site-packages/homeassistant/core.py", line 572, in __call__
    self.func(call)
  File "/srv/hass/lib/python3.5/site-packages/homeassistant/components/notify/__init__.py", line 106, in notify_message
    data=data)
  File "/srv/hass/lib/python3.5/site-packages/homeassistant/components/notify/telegram.py", line 102, in send_message
    self.send_photo(photo_data)
  File "/srv/hass/lib/python3.5/site-packages/homeassistant/components/notify/telegram.py", line 126, in send_photo
    photo=photo, caption=caption)
  File "/home/hass/.homeassistant/deps/telegram/bot.py", line 121, in decorator
    result = func(self, *args, **kwargs)
  File "/home/hass/.homeassistant/deps/telegram/bot.py", line 147, in decorator
    result = request.post(url, data, timeout=kwargs.get('timeout'))
  File "/home/hass/.homeassistant/deps/telegram/utils/request.py", line 227, in post
    data = InputFile(data)
  File "/home/hass/.homeassistant/deps/telegram/inputfile.py", line 94, in __init__
    self.mimetype = mimetypes.guess_type(self.filename)[0] or DEFAULT_MIME_TYPE
  File "/usr/lib/python3.5/mimetypes.py", line 289, in guess_type
    return _db.guess_type(url, strict)
  File "/usr/lib/python3.5/mimetypes.py", line 114, in guess_type
    scheme, url = urllib.parse.splittype(url)
  File "/usr/lib/python3.5/urllib/parse.py", line 861, in splittype
    match = _typeprog.match(url)
TypeError: expected string or bytes-like object
This is my lines in automation.yaml
- alias: 'Back Door Notify'
      platform: state
      entity_id: binary_sensor.2_door_chime_sensor_2_1
      state: 'on'
    service: notify.webcam_telegram
      message: "Someone is at the back door!"
      title: "Home Assistant"
        photo:
          - url: http://192.168.86.130/image/jpeg.cgi
            username: xxxxxx
            password: xxxxxx
Does anyone have any idea what I am doing wrong, or canā€™t I parse the URL to get the snapshot?
Thanks,
Finally Iā€™m able to help somebody! I made this yesterday. I doesnā€™t win any prizes, but it does the job. The next thing I want to do is create 5 pics, 1 second apart and telegram it. Should be easy with copy/paste but that not very elegant.
cfg/shell_commands.yaml
take_pic: curl -o /home/hass/snapshot.jpg -A cgi http://admin:[email protected]/image/jpeg.cgi
cfg/automation/test_telegram.yaml:
  • alias: ā€˜Test Telegramā€™
    • platform: state
      entity_id: input_boolean.test_telegram
      to: ā€˜onā€™
    • service: shell_command.take_pic
    • delay 00:00:10
    • service: notify.telegram
      title: Send
      message: Send Image
      photo:
      - file: /home/hass/snapshot.jpg
Hi @jilsx
Thank you for your help. I was able to get it to work wonderfully with my camera. I ended up for ease of use placing the shell_command right into my configuration.yaml file for now, but it works. Telegram seems to be sending me the message about 10 minutes later for some reason though; iā€™ll have to look into that.
I was able to get the automation to work with with this:
- alias: 'Back Door'
      platform: state
      state: 'on'
    - service: shell_command.take_pic_porch
    - delay: 0:02
    - service: notify.webcam_telegram
        title: Home Assistant
        message: Someone is at the back door!
          photo:
            - file: /home/hass/.homeassistant/snapshots/snapshot_porch.jpg
              caption: Back Porch Doorcam
Did you ever get your consecutive telegramā€™ed pictures working? I was thinking of doing the same thing and linking it to a motion sensor and automation rule.
Iā€™ve ended up with the following:
  • Send 1 pic via telegram
  • Send 10 pics (on second apart) via mail. I found this a little more elegant (to use my prior words). Probably can do it with Telegram and HASS alone, but Iā€™m already spending way to much time figuring out how that would work. Still getting used to the syntax.
The shell command Iā€™m using is:
#!/bin/bash
month=$(date +"%m")
day=$(date +"%d")
hour=$(date +"%H")
minute=$(date +"%M")
second=$(date +"%S")
folder=/mnt/sda/hass/camera1/$day$month-$hour$minute$second
mkdir -p ā€œ$folderā€
for num in {1ā€¦10}
do
curl -o $folder/$num.jpeg -A cgi http://admin:[email protected]/image/jpeg.cgi
sleep 1
done
mutt -s ā€œMotion Detectedā€ [email protected] -a $folder/*.jpeg < /tmp/mailmessage.txt
Just an update. Still havenā€™t figured out why there is such a huge delay between when the doorbell is pressed and the picture is taken and when I get the message. One thing I did do though that seems to ā€œspeedā€ up the process a bit is I have my automation set to send me a text notification of someone at the door, and then a second one for the picture. The text one comes in instantly and the photo about a minute later.
