Can't boot HA now
I’ve been running a docker installation of HA on a Raspberry Pi 3b for a few years, but now it’s not booting. I suspect that the problem has started after recent Core updates (but I’m guessing!).
I’m now in a situation where I can’t access the HA web page and also can’t ssh into HA (getting connection refused). All I can do is ping the Pi - so I’m stuck!
(I understand that the Pi 4 is a better choice for HA, but the migration is not straightforward and would need a complete new installation)
I’d be grateful for any sugesstions.
Jim
Attach a screen and keyboard and see what is going on ? Docker, so your SSH problem is not related to HA, unless HA eats all your CPU cycles or memory.
If you can’t get 3b up and running then it’s relatively straight forward to migrate to RPI4. I just installed the HA to the 4 and restored a backup from the 3 to it. I had no problems that I can remember at all.
Good idea Francis - I’ll give it a try tomorrow.
I’m not sure if it’s maxing out the CPU, as the heatsink is not very hot.
Jim
Thanks Spiro - your reply is encouraging. I’ll shop around for a RPI4.
Jim
I attached a screen and keyboard as Francis suggested and got a screenful of information relating to the Linux system booting. There appeared to be no errors.
The screen then cleared and displayed:
Waiting for the Home Assistant CLI to be ready…
[WARN] Home Assistant CLI not starting! Jump into emergency console…
I then have access to the OS file system.
If I then do:
ha
I get:
Error response from daemon: container (very long string) is not running
(I guess that the container refereed to is the one providing the CLI)
I’ve got no idea as to where I go now - but feel that there may be a possibility of recovery, but that if I’m not careful I can completely wreck the system!
I really ought to get up to speed with Docker, but I’m 85 years old and new concepts aren’t absorbed so easily!
BTW: I’ve got full backups on an external cloud account.
Jim
