Can't boot normally with 106, pls help!
I can’t boot into normal mode. I ran “Check HA configuration” app prior to updating but no critical errors were found (just Sonoff integration is no longer found apparently). I’m getting these three:
What to do? Thanks
Edit: the only issues from Check Config applet were this:
General Errors:
    - Platform error sensor.kodi_recently_added - No module named 'jsonrpc_async'
    - Component error: sonoff - Integration 'sonoff' not found.
