Can't call HA services/scenes/scripts with iOS Shortcuts
Hi, I’m trying to use NFC tags to run stuff via HA, HA Companion for iOS and iOS Shortcuts. I have an iOS Shortcut to run a HA script (to turn off everything when I tap the entry door tag). The script simply calls switch.turn_off services inside HA.
However, I can’t call these scripts via the Home Assistant commands. I call the “script.turn_on” service with this payload:
"entity_id: script.xxxxx"
That gives me this:
When called with curly brackets, {“entity_id: script.xxxxx”}, it gives me this:
The same goes for Scenes. Calling individual services like “switch.turn_on” in Shortcuts works as expected but I’m not entering that one by one into the Shortcuts app :slight_smile: Nothing related in HA log. Any tips?
EDIT: all the scripts and scenes DO work when called directly via HA web ui or automations.
I just got it working just adding two curly brackets in “text” field like this:
Thanks for this. Was very glad to find your answer without too much searching!
You’ll have a much improved experience with the Shortcuts for the app if you use the “Dictionary” action/methods, e.g.:
For the empty one, it looks like it will only error when you enter text and then remove it. I created a ticket for this.
Very cool, thanks!
Anyone else has ever experienced this?
When I try to select a service, it gives an error:
Try this:
{“entity_id”: “script.xxxxx”}
