Can't change Athom EU plug configuration
I have an athom EU plug that’s used to worked with ESPHome and HA.
Since the last ESPHome update (not sure if it is related) everytime I try to change the configuration of the plug. It comple and upload the code, then the plug go offline, and a new plug is discovered by ESPhome with a blank config (ie like it was fresh from factory except the wifi).
here is the config that I try to use. by the way, my only goal of chnaging the default config of this plug is because I want to change the update_time of the sensor from 10s to 500ms. If there a more elegant way to do that without put the whole config from athom, I will be glad to know.
substitutions:
  friendly_name: "10 - Outil atelier-f18736"
  project_name: "athom.smart-plug-v2"
  project_version: "1.1"
  relay_restore_mode: RESTORE_DEFAULT_OFF
#packages:
#  athom.smart-plug-v2: github://athom-tech/athom-configs/athom-smart-plug-v2.yaml
api:
  encryption:
    key: !secret 10_outil_atelier_encryption_key
wifi:
  ssid: !secret wifi_ssid
esphome:
  name_add_mac_suffix: true
  project:
    version: "${project_version}"
esp8266:
  board: esp8285
  restore_from_flash: true
preferences:
  flash_write_interval: 1min
ota:
logger:
  baud_rate: 0
mdns:
  disabled: false
web_server:
  port: 80
captive_portal:
dashboard_import:
  package_import_url: github://athom-tech/athom-configs/athom-smart-plug-v2.yaml
uart:
  rx_pin: RX
  baud_rate: 4800
globals:
  - id: total_energy
    type: float
    restore_value: yes
    initial_value: '0.0'
binary_sensor:
  - platform: status
  - platform: gpio
    pin:
      number: 5
      mode: INPUT_PULLUP
      inverted: true
    name: "${friendly_name} Power Button"
    disabled_by_default: true
    on_multi_click:
      - timing:
          - ON for at most 1s
          - OFF for at least 0.2s
        then:
          - switch.toggle: relay
      - timing:
          - ON for at least 4s
        then:
          - button.press: Reset
  - platform: uptime
    name: "${friendly_name} Uptime Sensor"
  - platform: cse7766
    update_interval: 500ms
    current:
      filters:
          - lambda: if (x < 0.060) return 0.0; else return x;   #For the chip will report less than 3w power when no load is connected
    voltage:
    power:
      filters:
          - lambda: if (x < 3.0) return 0.0; else return x;    #For the chip will report less than 3w power when no load is connected
    energy:
      unit_of_measurement: kWh
      filters:
        # Multiplication factor from W to kW is 0.001
        - multiply: 0.001
      on_value:
        then:
          - lambda: |-
              static float previous_energy_value = 0.0;
              float current_energy_value = id(energy).state;
              id(total_energy) += current_energy_value - previous_energy_value;
              previous_energy_value = current_energy_value;
    name: "${friendly_name} Total Energy"
    device_class: "energy"
    state_class: "total_increasing"
    icon: "mdi:lightning-bolt"
    accuracy_decimals: 3
    lambda: |-
      return id(total_energy);
  - platform: total_daily_energy
    name: "${friendly_name} Total Daily Energy"
    restore: true
    power_id: power_sensor
    filters:
      - multiply: 0.001
button:
  - platform: factory_reset
    name: "Restart with Factory Default Settings"
  - platform: safe_mode
    internal: false
switch:
  - platform: gpio
    pin: GPIO12
    restore_mode: ${relay_restore_mode}
light:
  - platform: status_led
    name: "${friendly_name} Status LED"
    pin:
      inverted: true
      number: GPIO13
text_sensor:
  - platform: wifi_info
    ip_address:
    ssid:
    mac_address:
time:
  - platform: sntp
Hi, I read you configuration and compared it against mine. It’s very similar to the standard and I see no obvious issues.
You would be best to connect the plug to a serial interface and look at the errors during the flash process just in case there are some data problems as I wonder if the flash may be corrupt?
I searched on how to open the new plug but it’s not obvious, I could only find info for the older EU type:
Maybe this will help.
