Can't change brightness via Automation?
Hi guys, I’m really struggling here with trying to increase and decrease my brightness with an automation.
I’ve tried all of the below with now luck.
Brightness 4 will change the brightness to 100 on the Dimmer in console.
Brightness 2 will just set the brightness_pct value to the initial 50
 - alias: 'Brightness3'
      platform: state
      entity_id: binary_sensor.dimtest
      - service: light.turn_on
        entity_id: light.lamp4
        data_template:
          brightness: >-
            {{  states.light.lamp4.attributes.brightness | int + 10 }}
  - alias: 'Brightness4'
      platform: state
        data_template:
          brightness: '{{states.light.lamp4.attributes.brightness + 10}}'
  - alias: 'Brightness'
      platform: state
        data_template:
          brightness: >
             {% set suggested = states.light.lamp4.attributes.brightness |int + 10 %}
             {% if suggested < 200 %}
             {{ suggested }}
             {% else %}
             200
             {% endif %}
  - alias: 'Brightness2'
      platform: event
      event_type: click
      event_data:
        entity_id: binary_sensor.button_id
        click_type: single
        data_template:
          brightness_pct: >
            {% set step_size = 50 %}
            {% set cb = (state_attr('light.lamp4', 'brightness') | float / 255.0) * 100.0 %}
            {% set new_brightness = cb | int + step_size %}
            {% if 91 <= new_brightness < (90 + step_size) %}
              100
            {% else %}
              {{ new_brightness if new_brightness < 100 else 0 }}
            {% endif %}
