Cant change height of calendar card using card mod
Why cant I change height of the calendar card ?
type: calendar
entities:
  - calendar.mymail_gmail_com
initial_view: dayGridDay
card_mod:
  style: |
    ha-card {
      min-height: 200px !important;
      color: red;
It accepts the color change but not the height. The height is just greyed out like so:
If I change this in the developer console it does exactly what I want:
Can anyone help?
This is my solution:
  - type: calendar
    entities:
      - calendar.mailo_gmail_com
    card_mod:
      style:
        ha-full-calendar:
            #calendar {
              min-height: 150px !important;
Is this a custom card or where did you put this bit?
Its not a custom card but I’m using
card mod
Thank you, found it.
I’ll give it a go.
sorry to piggyback on this but the Spousal Approval Factor is at stake.
I have the calendar on an Inkplate 10 and thankfully, I found your thread about the height which helped a lot but the spacing between the event lines is so big that the calendar still only shows 2-3 events.
Do you know by any chance on how I’d be able to reduce the spacing and how I could change the past events to not “fade” (wife thinks the grey events make it look “broken”).
Big thanks to anyone who can help me :slight_smile:
Hey @motz ,
Spousal approval factor are the most important , I know what you are talking about !
I have tried to make some changes for you , maybe that can help…
card_mod:
  style:
    ha-full-calendar:
        #calendar {
          min-height: 230px !important;
        .fc-day-past .fc-daygrid-day-events {
          opacity: 1 !important;
        .fc .fc-daygrid-event {
          padding 0px !important;
          margin 0px !important;
@cvester You rock! The events are not faded any more! I think that’s the most critical part as it looks good now.
The .fc .fc-daygrid-event didn’t seem to change anything for now but that direction on how to play around should already help me get there eventually.
Thanks again! Man, I love this community.
Edit: height: did the trick! Yay!
          height: 15px !important;
Good you found a solution , I’m glad I could help ! :grin:
this worked great for me…many thanks…to be fair it was nitpicking for me but HASS is all about a tinkering session
Hello, I am also trying to extend the height of the calendar view, but no success.
I would like to fill in the blank space at the bottom of the card … the width is ok though :
      - initial_view: dayGridMonth
        type: calendar
        entities:
          - calendar.ceccccdrccccole_gmail_com
        card_mod:
          style:
            ha-full-calendar:
                #calendar {
in fact as far as I can see now that I have setup a black background, it increases the height of the “card”, but not the height of the table (calendar itself), as you can see :
… here is my complete code :
kiosk_mode:
  admin_settings:
    hide_header: false
    hide_sidebar: false
  non_admin_settings:
    kiosk: true
  - title: Home
    sections: []
    type: custom:grid-layout
    layout:
      grid-template-rows: 75px 500px
      grid-template-columns: 600px 600px
      grid-template-areas: |
        "head1 head1"
        "col1 col1"
    cards:
      - type: custom:mushroom-chips-card
        chips:
          - type: entity
            entity: person.delecole
            tap_action:
              action: navigate
              navigation_path: /lenovo-m10-plus-home/0
            content_info: name
            icon: mdi:home
            use_entity_picture: false
            icon_color: yellow
        view_layout:
          grid-area: head1
        type: calendar
        entities:
          - calendar.xxxxxx_gmail_com
        card_mod:
          style: |
            ha-card {
              background: black;
              min-height: 600px !important;
              border: 0px;
        view_layout:
          grid-area: col1
Many Thanks !!
My guess would be that you target the ha-card like this:
ha-card {
              background: black;
              border: 0px;
and not like this
ha-full-calendar:
                #calendar {
this seems to be working for me
style: |
    ha-full-calendar {
      --calendar-height: 600px !important; /* Adjust the height as desired */
No luck for me … I have put a black background, and as you can see only this background is changing, but not the table itself ?!?
        type: calendar
        entities:
          - calendar.xxx_gmail_com
          - calendar.yyy_com
        card_mod:
          style: |
            ha-card {
              background: black;
              border: 0px;
        view_layout:
          grid-area: col1
@cvester
oh but wait … you are using ha-full-calendar ??? Where is this coming from because indeed, this wording is changing the calendar itself, it seems …
        card_mod:
          style: |
            ha-full-calendar {
              background: black;
              height: 800px !important;
              border: 0px;
and now it seems to be dimensioning in height :
Is there some doc explaining this ?
I though “ha-card” was a card-mod parameter, but now we talk about ha-full-calendar ???
ha-card is the root but I figured it was better just to go straight to the sub element
its funny that I send you something that indeed does work , then you do whatever you want and write back to me that it doesnt work.
Well yes, the card-mod docs explain everything.
Well, actually yes, it works with ha-full-calendar.
It is still not ok for me, because even if it shows a nice calendar and size adapted to my dashboard, what I want in final is a 7 columns) days view …
You know about a way to have such with with this calendar card ?
You seems to be expert the coding
:wink:
If you try to draw / illustrate it to me I can give it a try
Super thanks !!
What I would like to achieve, is such view with the ability to go from weeks to weeks :
and basically even a single week is also ok :
… this I can achieve using anther card called “week-planner”, and this is what I would like to achieve using the standard card. For the moment with the standard card I can not have a view like this in columns ;-(
